Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 29, 2007
Old    hannah (cwbx993)      Join Date: Feb 2007       10-11-2007, 7:40 PM Reply
i was trying to get my friend into wakeboarding this summer and i finaly succeeded and he bought his own board(a cheap hydroslide 135 cm)the problem is our boat only has a 115 h/p motor and his boat only has a 90. hes pretty big(6,0 160lbs)and the boat just draggs him through the water until he cant hold on and has to let go of the rope. so he never gets to the point where he;s able to stand, do you think the board is too small, or is the motor? im pretty sure its not his technique but hey I could be wrong.
Old    Mike Odenwaelder (hyperlite_boards)      Join Date: Aug 2007       10-11-2007, 7:44 PM Reply
i rode behind a 90 hp at my friends house once im 6ft 4in 170lbs and it was really hard to get the boat to accelerate so i could get up easily but when i did it was fine. it should be ok
Old    Jay Conrad (pwningjr)      Join Date: Apr 2007       10-11-2007, 7:45 PM Reply
We used to (as in until late this year) ride behind an 80 horse outboard, I would assume that the engine isn't the problem. It looks to me that the board might be too small. Either that or technique, in which case my post doesn't help much. Ah well.
EDIT: Irrelivent, but I thought I would just share this for the heck of it. When my dad used to slalom, he skiied behind a 6 horse engine... The ski was more pushing through the water than on top of it, but he was still up. It amazes me to this day.
(Message edited by pwningjr on October 11, 2007)
Old    walt            10-11-2007, 8:06 PM Reply
I watched a guy wakeboard behind a 15 HP tin boat at the end of summer. I have no idea how he got up but he did.
Old    Scott Dearduff (clearlakescott)      Join Date: Apr 2007       10-11-2007, 8:07 PM Reply
That is plenty of hp for a small boat. 160lbs is not a big rider. Work on the technique of getting up. many people try to force getting up and end up pushing the board underwater instead of allowing it to stay on top.FWIW: We used to have a sea ray with 90hp and as heavily weighted as it would get and still pulled a bigger guy then you are trying to.
Old    Matt Heil (wakestar517)      Join Date: Jun 2006       10-11-2007, 8:14 PM Reply
thats plenty of power I have ridin behind a 25hp before (5'9" 190) it did take some doing but a 90 is more then enough.
I think dan is right he is doing something wrong.One more trick to do is once up stay in a butter slide till the boat speeds up it creates less drag.
Old    John Anderson (fly135)      Join Date: Jun 2004       10-11-2007, 8:17 PM Reply
"im pretty sure its not his technique but hey I could be wrong."
Totally a lack of technique.
Old    Dex (tarpongator)      Join Date: Jan 2006       10-11-2007, 8:27 PM Reply
My first time up was behind a 14 ft jon boat with a 25 hp. I am 6'0 185 lbs. We used that boat for three months. I was also on a board that was too small. I say it is technique.
Old    Jos (jtnz)      Join Date: Sep 2007       10-11-2007, 9:30 PM Reply
I'm 6'2" 75 kg, around 160 lb. I've skurfed behind a 12 foot tinny (2 up, driver and spotter) with a 10 horse motor on my 6'6", it didn't pull very well, was hard to get the board to plane, but once it did it went pretty hard. Pulled me out is the important part anyway, it can be done.
Old    scott clark (snwmot)      Join Date: Sep 2006       10-11-2007, 11:42 PM Reply
i ride behibd a 250cc quad in a canal sometimes i'm 6'2 240 lbs and i can get up no prob it's probably technique bro just work on it u'll get it down.
Old    Jon Hunter (hunter660)      Join Date: Aug 2007       10-12-2007, 6:10 AM Reply
I'm 5'11"@175lb, I wake behind a 115. No problems here.
Old    Nacho (denverd1)      Join Date: May 2004       10-12-2007, 7:33 AM Reply
start with the board under the water. not on top. as the boat moves forward try to think of sliding it through the water, letting the boat pick up speed, instead of trying to force yourself up quickly by immediately pushing the water with all your weight. takes a little practice, but you should be able to get up.
Old    Matt (nowake)      Join Date: Jul 2007       10-15-2007, 7:25 AM Reply
My 17' boat has only 50HP (30mph top speed) and we have a couple 180# guys who ride just fine. Have him stay squatted on the board, and like mentioned above let the board slide on top of the water. Once he's sliding he can stand right up.
Old    AtTheLake (bmartin)      Join Date: Jan 2007       10-15-2007, 9:13 AM Reply
The Jury verdict is in. Plenty of HP! Try watching some vids. Once he gets it, the 90 or the 115 will pop him right up.
If you feel you have to have more hole shot, you can get a lower pitch prop for the motors. Just watch for over-revs if you do.
Old    hannah (cwbx993)      Join Date: Feb 2007       10-15-2007, 4:48 PM Reply
allright thanks for the advice everyone hope we getout again before winter!
