Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through October 14, 2007
Old    txwakejunkie (txwakejunkie)      Join Date: Oct 2007       10-01-2007, 9:01 PM Reply
Its time to replace the 05 CWB flame 141. I'm a heavy guy (6'1" 250lb) and I was wondering if size really makes a big difference. I am looking at the Ronix Ibex and I am wondering if the 139 or the 144 is best for me. If I get the larger of the 2 will I be sacrificing pop because of the additional weight of the board?
Old    Brad (brad63)      Join Date: Jun 2006       10-01-2007, 9:04 PM Reply
go with the 144
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       10-01-2007, 9:06 PM Reply
Size definitely matters imo I weigh between 210 and 215 last year I rode a 139 and now I ride a 143 and it made a huge difference in my pop and overall riding
Old    Rich (rson)      Join Date: Jun 2002       10-01-2007, 9:06 PM Reply
I don't think you are sacrificing pop because you are increasing the surface area of the board to pop you off the wake. You are sacrificing swing weight for spins etc.
Can you demo? Feel of board is very subjective. I am 5'11 and 160...my favorite board has been a 142 Project. Very stable and I had no issue getting air.
DEMO DEMO DEMO.
Old    Steve (sdmjr)      Join Date: Jul 2007       10-01-2007, 9:09 PM Reply
I have the ibex 144. it has real good pop but i have not rode the 139, i actually have the same question, I'm 6'4" 230. i really like the board it is really light. this is my first season so only time will tell. I hope that someone has more info.
Old    Steve™ (kingskrew)      Join Date: May 2004       10-01-2007, 10:29 PM Reply
IMO, don't even consider the 139. 144 all the way.
-Steve
Old    Cliff Griffin (seattle)      Join Date: Mar 2002       10-02-2007, 7:35 AM Reply
The Ibex rides real small. I'd go with the 144 for sure. You can also demo these.
http://wakeworld.com/boardguide/getboard8.asp?ProductID=3570
http://wakeworld.com/boardguide/getboard8.asp?ProductID=3417
http://wakeworld.com/boardguide/getboard8.asp?ProductID=3467
http://wakeworld.com/boardguide/getboard8.asp?ProductID=3456
They're boards I've ridden that fit me pretty well. I'm 6' 220lbs.
Old    Robert A. Rodriguez (robertr720)      Join Date: Aug 2007       10-02-2007, 9:06 AM Reply
You will actually gain more pop by going with the bigger board and will feel much more stable aswell. I'd recommend the 144 if you came into my store. You can't go wrong if you demo though. a bigger board will help your landings too because the board is not going to have the sinking feeling that you will get being on a smaller board.
Old    Brooke (dizzyg)      Join Date: May 2005       10-02-2007, 9:14 AM Reply
I'm at about 190 right now and was riding a 134, now I ride a 140. I didn't notice a big difference in pop so long as I had enough speed. I found myself riding faster than I usually would with a smaller board but I'd still get good pop so long as I didn't sink or slow down coming in.
I did notice that if I was going to land at all squirrely, I was going to fall on a smaller board. With a bigger board I have a little more wiggle room and it really helps me when I'm just a little off on the landing. I can still ride away where on the small board, if my weight wasn't centered, that was the end of it.
Old    Isaac Gredinberg (extremeisaac)      Join Date: Aug 2005       10-02-2007, 10:08 AM Reply
can we get a females opinion on this?
Old    Adam (blindmnkee3)      Join Date: Aug 2001       10-02-2007, 11:41 AM Reply
Thinking about the new 08 Marius 140 for me. I used to ride a Premier 140 (back in 03 or so) and loved it and then went to Parks 142. I think the bigger board helped quite a bit.
Do you all think the super wide Marius will feel similar to a longer board? Or should I prob look at an Ibex 144. BTW, I'm 6'7'' 235. Very limited demo options here.
Thanks for your input fellas :-D
Old    Jon Hunter (hunter660)      Join Date: Aug 2007       10-02-2007, 12:03 PM Reply
I just started this year and got a motive 134 by recommendation from my dealer. I am 5'-11" & 175#. I would really like to try a bigger board. I think it might work better for me.
Old    Eubanks (eubanks01)      Join Date: Jun 2001       10-02-2007, 12:12 PM Reply
6'7"?? Have you grown in the last few years??!
You need to come to Dallas and have a reunion with me and the Skull (aka: Rob).
Old    Jruss (oaboards)      Join Date: Aug 2007       10-02-2007, 1:00 PM Reply
Marius 140 will be the best board you ride
Old    Josh (romes)      Join Date: Sep 2006       10-02-2007, 2:05 PM Reply
if you can find one...the LF Axis 143 is a super easy board to ride...consistent pop, loose when I like it to be and still holds a very solid edge (alot like the shane)...not too fast and not too slow...and i've ridden every board in the LF line-up this year...you might also want to take a look at the Witness 144...SOLID board
just my opinion
Old    txwakejunkie (txwakejunkie)      Join Date: Oct 2007       10-02-2007, 4:26 PM Reply
thanks for all the info, looks like i need to demo for the best results. Sounds like i will be better off with the bigger board.
Old    Lantz (elantz)      Join Date: Jul 2006       10-02-2007, 4:47 PM Reply
tx, water conditions also play a role in length of board and rocker style, for me.
Crappier the water = more length, less abrupt rocker and more fin
Smoother water = less length, abrupt 3-Stage and finless
I ride from a 141 to a 147 depending on conditions. 6' 220lbs
The 139 seems pretty short for a big dude like you. I've ridden boards down to 133 (girls) and I can make them all pop but the landings are brutal for me on those short boards.
Old    txwakejunkie (txwakejunkie)      Join Date: Oct 2007       10-02-2007, 7:38 PM Reply
i think i will go with the softer landings. thanks
Old    Chqwakeboarder (chqwakeboarder)      Join Date: May 2006       10-02-2007, 8:57 PM Reply
We have a 136 Parks and a 138.1 Murray. I'm 6'4" and weigh about 215 and ride the Murray. A good friend of mine is about 10 pounds heavier than me and the same height and will only ride our Parks when he doesn't have his board with him (a 135 3ds). He's said that he does sacrifice a little air ridin the really small board, but does it for the low swing weight. From what i noticed, he really has to cut unusua'ly hard into the wake to set up his tricks on such a little board. He's really unusual though, but you too might like a smaller board. Demo both sizes and see what you like.
Old    Adam (blindmnkee3)      Join Date: Aug 2001       10-02-2007, 11:39 PM Reply
I'll just have to demo whatever I can get my hands on. Everything I've read about the Marius has me intrigued. I'm getting a little sick of the bucking style of the Parks board, its fun, but I want to get a little more smooth. Plus I'm diggin the set up shown here
http://www.wakeworld.com/MB/Discus/messages/1/506831.html?1191361058
08 Marius 140 and 08 Zues...Not bad at all
Jarrett,
Yeah bud I'll be back for about a week around Christmas. I'll email ya when it gets closer
