4 will work, but 2 or 0 would be better. Hook the negatives like you said. Hook all the wires that were previously hooked to the battery to the common. Hook the positive of the original battery to #1. Hook the positive of the added battery to #2. I personally run all amps off the common, that way whatever the perko is swiched too will be the only one draining. Hope this helps.
