Old     (chaser)      Join Date: Sep 2006       09-24-2007, 6:45 AM Reply
Changed the steering cable in my 02 X-star earlier this season. Put on about 75 hours since the cable was replaced. Yesterday noticed the steering seemed stiff. I have greased it once since I changed the cable. Couldn't be the cable going bad already again, could it? Also, when storing the boat, I read you should keep the wheel turned one way or the other to keep the cable either fully retracted or fully extended. Can't remember which way was recommended?
Old     (denverd1)      Join Date: May 2004       09-24-2007, 9:16 AM Reply
should be a couple zerks back there. 3 i believe. Did you hit them all?
Not sure about turning the wheel. never heard that.
Old     (dreevs)      Join Date: Jul 2002       09-24-2007, 10:33 AM Reply
No salt in Wisconsin I guess?
Old     (chaser)      Join Date: Sep 2006       09-24-2007, 1:40 PM Reply
nope, no salt here. It is getting cold though? Could cold grease make that much of a difference?
Old     (etakk7)      Join Date: Apr 2006       09-24-2007, 8:43 PM Reply
I've heard of Minnesota boaters complain of stiffer steering in the fall and spring. I always fold my cable in (wheel to the right). Never been told to do so, just seems to be the best thing.
Have you greased the rudder?
Also, overgreasing will cause it to be stiff the first few turns before it spews out the excess.
Old     (timmy)      Join Date: Jul 2001       09-25-2007, 5:08 AM Reply
is there water in the bilge?
Old     (chaser)      Join Date: Sep 2006       09-25-2007, 10:17 AM Reply
no water in the bilge Tim.
Old     (curtisco24)      Join Date: Dec 2005       09-25-2007, 2:32 PM Reply
sounds like another cable.
Old     (laraujo)      Join Date: Apr 2007       09-25-2007, 3:01 PM Reply
I thought I saw an earlier thread on this subject and the problem was the rudder. There was a redesign on the MC rudder pre 2003 and the pivot shaft was changed (larger) due to failures of the earlier ones. I know this is the case for the supra pre 2003 rudder as well where steering is stiff even after changing the cable
Old     (bmartin)      Join Date: Jan 2007       09-26-2007, 7:55 AM Reply
Are there grease fittings for the rudder / steering cable? If so where? I saw another post that eluded to them. Thanks.
Old     (etakk7)      Join Date: Apr 2006       09-26-2007, 12:16 PM Reply
yes, there is a grease fitting on the rudder, in the bilge, facing the bow. There are two grease fittings on the steering cable shaft, about midway in the bilge on the starboard side
