Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 10, 2007
Old     (bbking)      Join Date: Dec 2006       09-10-2007, 2:47 PM Reply
so my dad thinks i should work on spins with my wakeboard on, fins off, on the trampoline...
is this gonna damage by board or the trampoline? thanks
Old     (h2o_junkee)      Join Date: Apr 2007       09-10-2007, 2:55 PM Reply
Depends on your board....I use an old wood wakeskate with no bottom contours. Screw in some shoes and you're good to go.
Old     (sup208)      Join Date: May 2004       09-10-2007, 3:01 PM Reply
My sons took the fins off their boards and it works fine. To give it more of a realistic feel we took the rope and tied knots in it about 3 ft apart and hooked a couple of bungees in the rope so it always has tension and yet you can pull it tight. We are using an old CWB SOL and and old skate board deck with shoes screwed to it.
Old     (ronnyboy27)      Join Date: Nov 2005       09-10-2007, 3:14 PM Reply
Depends on what board you have some will tear up a trampoline with the molded in fins.
