Old    Bryan Madson (mads0113)      Join Date: Aug 2006       09-10-2007, 12:16 PM Reply
If have some small surface scratches that I would like to try and buff out on my boat. Can anyone give me advice on what type of wax or compound I should use to do this? Thanks
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       09-10-2007, 12:33 PM Reply
Search for an article written by Grant "G" West. He outlines the entire process with products and pictures.
Old    Eder Garavito Garavito (spicychalupa69)      Join Date: May 2005       09-10-2007, 2:12 PM Reply
Bryan, here it is, its a great article and my boat is still due for some of Grant's boat care tips. Read it in full detail, great stuff http://www.wakeworld.com/MB/Discus/messages/65921/282492.html
Old    George Aslinger (mobv)      Join Date: Jun 2002       09-10-2007, 6:49 PM Reply
3m Super Duty Rubbing Compound, foam pad on a slow speed buffer, then finish with 3m Marine Finishing compound.
Old    Mike B (mlb75)      Join Date: Aug 2007       10-15-2007, 6:08 AM Reply
second the 3M products you won't believe the difference
Old    Buzz (buzz_grande)      Join Date: Mar 2004       10-15-2007, 12:50 PM Reply
Start off with a medium or fine polishing compound first. If that does not take it out, then move to something more aggressive. If you start with a heavy compound, it will take a lot more work. Usually a rubbing compound like 3M Super Duty may be a bit aggressive. Like I said, start with a polish that is not too aggressive, and work up from there. You will be surprised what you can get out.
Old    Ronia (ladythump)      Join Date: Jul 2004       10-15-2007, 1:43 PM Reply
3m is good but hard to get off... Also look into the Meguiars products.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       10-15-2007, 1:49 PM Reply
Like buzz said if the scratches are not deep in the gelcoat try polish first with a high speed buffer. The buffer heats up the gelcoat and blends it in for a lack of a better description. If you haven't used a high speed buffer before I'd call a buddy that has.
Old    Da MOOSE (da_moose)      Join Date: Feb 2004       10-16-2007, 2:44 PM Reply
220,320,400,600,1000,sand with,soap& water.get a 5000 polisher with compound.3-5 coats for wax.
Old    Allen Sasser (bamacpa)      Join Date: Aug 2006       10-16-2007, 9:48 PM Reply
How do you work around stickers/decals/graphics on the boat? I assume a heavy compound would completely destroy them, but what about a fine polishing compound (finishing compound)? I have a good bit of decals on mine.
Old    Da MOOSE (da_moose)      Join Date: Feb 2004       10-19-2007, 2:52 PM Reply
tape'm with blue tape.This is where skills come in.
