Old    chase butler (truebeachbum)      Join Date: Oct 2006       09-09-2007, 3:32 PM Reply
in the rear lockers it says do not go over 75 pounds in here not made for ballast. is that so u wont go over the weight limit or is it cause the tank will break
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       09-09-2007, 4:11 PM Reply
We put a 750 in back there for surfing just fill the hard tank first.
Some guys totaly remove the hard tanks but we day camp and need the room. when we have a lite crew we add 2 - 450 sacs in the trunks.
Do you have the full 4 tank MLS?
Old    Stan Tanner (sbt3)      Join Date: Jun 2002       09-09-2007, 5:07 PM Reply
my buddy has been running the 750 fly high pro x on top of his vlx for 2 seasons now without any problems. We always have the stock tanks full though not sure how it would be if they were left empty.
Old    David (tparider)      Join Date: Aug 2003       09-09-2007, 5:56 PM Reply
As long as the rear tanks are full of water, you don't have anything to worry about there. Just fill the factory ballast and then fill whatever sacs you're going to put in the rear comparments.
We use stock plus 440lbs on each side of the engine, 700lb on the floor, and 2 250 sacs in the bow.
Old    billy foulds (mcwakerider)      Join Date: Dec 2006       09-09-2007, 8:43 PM Reply
david
Any picks of ur wake?
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       09-10-2007, 8:57 AM Reply
Chase this is a good read
http://www.wakeoutlaws.com/kdetail.php?k_id=KY1161886021K4540f9453685e
Old    Larry (larrys)      Join Date: Jun 2005       09-21-2007, 11:57 AM Reply
Why does it matter if the tanks are full??? Since it is an open system, the water is not providing any support.
Old    Billy (woreout)      Join Date: Aug 2006       09-21-2007, 12:38 PM Reply
Its not the tanks their worried about crushing, its the floor. The floor in the storage areas and walk thru are not the same as the floor in the rest of the boat. Bu's are not a one piece tub inside but several pieces screwed together, and they use cheaper material for the storage areas. Thats the reason for the warning stickers in the rear lockers.
Old     matt c (curtisco24)      Join Date: Dec 2005       09-21-2007, 2:23 PM Reply
not unless they changed the floor in 05 when they went to the "underground tanks" which I doubt. The reason for the stickers is that the tanks will crush when empty.
Old     matt c (curtisco24)      Join Date: Dec 2005       09-21-2007, 2:24 PM Reply
I've seen malibus with 500 pounds of lead on each side of the engine on the floor 04 back and not even a dent in the floor.
