Old    Tara Wooden (teedub01)      Join Date: Aug 2007       08-28-2007, 3:48 PM Reply
I just bought a 2004 Supra Launch in March. A few weeks ago the engine started to run rough and it sounded like it was running uneven, if that makes sense. I took it to a shop and they said that two of the eight pistons are running at 4 and 5 pounds of pressure instead of 170. Anybody have any idea what the problem could be?
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       08-28-2007, 4:19 PM Reply
Rings are shot or potentially a blown head gasket. Time for a top end rebuild. Essentially resurfacing the heads, replacing the head gasket and putting new rings on the pistons. Not cheap.
Pre-mature piston ring wear is usually caused by poor maintenance. Although there are a lot of people on this site that know more than I do about this issue.
Old    Big E. (wakesetter101)      Join Date: Oct 2005       08-28-2007, 4:33 PM Reply
I would bet you have a blown head gasket. Are the two cylinders with low compression side by side? If thats the case (and i bet money that it is).
You will need to pull the intake and then the head. Not that big of a deal. Just a pain.
Old    Tara Wooden (teedub01)      Join Date: Aug 2007       08-28-2007, 4:34 PM Reply
The engine only has 92 hours on it and I know for a fact that the previous owner took immaculate care of the boat/engine with regular tune-ups etc. Plus, I had it surveyed before I bought it and the surveyor said it was in pristine condition. It had been running just fine this whole summer and then this. I am seriously at a loss...
Yes, they actually are side by side
Old    T-Bag (nasty530)      Join Date: Aug 2007       08-28-2007, 6:42 PM Reply
Like Big E has stated, chances are it is a blown head gasket. This is certainly less than needing a rebuild but still not cheap. Take it to a traditional auto mechanic, my experience has been that they are a little less expensive then boat dealerships and there is nothing much different about the engine.
Old    Big E. (wakesetter101)      Join Date: Oct 2005       08-28-2007, 6:51 PM Reply
Are you going to try to tackle this yourself? It could be done on a Saturday. Head gaskets normally run around $50 bucks i would guess.
Old    Tara Wooden (teedub01)      Join Date: Aug 2007       08-28-2007, 7:09 PM Reply
No, I probably won't tackle it myself. I don't know enough about engines to even go there. Plus, I want it done right. Any guess as to how much this could be?
Old    Leo Lasecki (malibuboarder75)      Join Date: Jan 2004       08-28-2007, 7:33 PM Reply
Maybe find a guy in the neighborhood who works on engines and pay him to help you.
Old    Tara Wooden (teedub01)      Join Date: Aug 2007       08-28-2007, 7:42 PM Reply
That actually might be a good idea. I really want to have it fixed before Labor Day weekend and that's probably my best hope. We'll see, thanks for the tip though!
Old    Bob (bob)      Join Date: Feb 2001       08-29-2007, 3:22 AM Reply
If you plan on tackling it yourself, even with an experienced persons help, get the shop manual. Seems to me you need to find the cause to prevent a second blown gasket. Did the warning horn ever come on, telling you that it overheated?
Old    Paul (psudy)      Join Date: Dec 2003       08-29-2007, 10:25 AM Reply
It could be a burnt valve as well. That happened to my boat, and they just replaced the valve. It wasn't cheap, but nothing a mechanic does to a boat is.
(Message edited by psudy on August 29, 2007)
Old    Tara Wooden (teedub01)      Join Date: Aug 2007       08-29-2007, 11:38 AM Reply
No, nothing came on that the boat was overheating.
