Old    tigegirl (tigegirl)      Join Date: Sep 2005       08-18-2007, 1:01 AM Reply
Is there storage in the bow? I know the center cushion comes out, but are there storage compartments under the other 3 cushions? thanks
Old    Heeb (heeb_v215)      Join Date: Feb 2007       08-18-2007, 1:19 AM Reply
Yes there is the little front one is like a tiny cooler and the two on the side are storage..
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       08-18-2007, 11:55 AM Reply
What is the top end on a gps of the 215 with no weight and not porpusing? with the 330 hp scorpion. Anyone have any pictures of the wake at wot
(Message edited by krbaugh on August 18, 2007)
Old    Art (rallyart)      Join Date: Nov 2006       08-18-2007, 12:26 PM Reply
Kevin, my D215 does 42 at 2000 foot altitude with a 12 pitch prop but I'm not at my peak rev range so I will have.to drop pitch and should actually pick up 1 or 2 mph
I can't post a pic soon but it never popoises and is clean but noticable. I have the 330 hp
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       08-18-2007, 1:34 PM Reply
Ok that is very close to what My Enzo 216 is getting
Old    Eric (rowdy)      Join Date: Mar 2006       08-18-2007, 2:47 PM Reply
Kevin, I did 48.5 this morning with 3 people in the boat with the stock prop. I was at 800 ft altitude, almost an empty tank of gas, and fairly smooth water. I don't have a pic of the wake at that speed. I can get you one the next time out.
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       08-18-2007, 3:40 PM Reply
48.5 on a GPS?
Old    Eric (rowdy)      Join Date: Mar 2006       08-19-2007, 8:54 AM Reply
Yep, 48.5 on a GPS...Garmin 60csx to be exact. I just adjusted my throttle cable since the boat was never winding out. The Black Scorp would only top out at about 4900 rpm. Now it goes to 5200 no problem and I was shocked at the amount of top end I gained.
Old    Ken (ghostrider_2)      Join Date: Aug 2004       08-19-2007, 11:32 AM Reply
just curious how did you adjust your throttle cable?
Old    Eric (rowdy)      Join Date: Mar 2006       08-19-2007, 3:45 PM Reply
Kenny, I adjusted the clamp that holds the cable to the motor. I also went to the lever and adjusted there, decreasing the angles where I could. I lubed the cable as well. I'm heading over to your other thread.
Old    Ken (ghostrider_2)      Join Date: Aug 2004       08-19-2007, 4:03 PM Reply
how did you lube the cable?
(Message edited by ghostrider_2 on August 19, 2007)
Old    Eric (rowdy)      Join Date: Mar 2006       08-19-2007, 4:06 PM Reply
I just put grease in at either end of the housing and worked it in...I don't know how much it really did, but it does feel a lot smoother. I was figuring that the most friction is at either end, where the bends are, so that's where grease it probably needed.
Old    Ken (ghostrider_2)      Join Date: Aug 2004       08-19-2007, 4:08 PM Reply
guess I could do that now also. Thanx
Old    MIKE V (madvlin)      Join Date: Jun 2007       08-20-2007, 3:19 PM Reply
my 215 has never seen over 25 mph j/k but it seems that way. Wrong boat to go fast with
Old    Eric (rowdy)      Join Date: Mar 2006       08-20-2007, 3:30 PM Reply
But it's a Sanger....going fast is in its' DNA!!!
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       08-20-2007, 4:04 PM Reply
"Wrong boat to go fast with"
Why?
Old    walt            08-20-2007, 4:15 PM Reply
Kevin,
I'm not sure what the top speed is but I've been with Coop when he's pulled footers (long line).
I've been in a VLX while pulling footers too.
My guess would be around 46-47.
Old    mendo247            08-20-2007, 4:28 PM Reply
Thats pretty close, maybe 45? Ballast empty, but did have some lead in the boat...
Old    DRA-Doug (load)      Join Date: Jul 2003       08-20-2007, 4:38 PM Reply
Some lead!
