Old     (danny_h)      Join Date: Aug 2007       08-15-2007, 8:26 PM Reply
this thing is going to knock!!!!
Old     (danny_h)      Join Date: Aug 2007       08-15-2007, 8:32 PM Reply
so after alot of planing and math where is what i came up withUpload
Old     (lovin_the_wake)      Join Date: Jul 2007       08-15-2007, 8:32 PM Reply
thats very interesting looking im pretty sure that things gonna bump a lil
Old     (danny_h)      Join Date: Aug 2007       08-15-2007, 8:40 PM Reply
a few more i had to cut the box in half to make it fit then screw it all back oh yea is tuned to 30 htz togetherUpload
Old     (ponte_06_x2)      Join Date: Jan 2006       08-15-2007, 8:41 PM Reply
remember brotha. resin resin resin. it would be better to resin the inside and outside of the box. looks dope
Old     (danny_h)      Join Date: Aug 2007       08-15-2007, 8:45 PM Reply
yes thats my next step tomorrow many layers of resin and thanks
Old     (hatepain)      Join Date: Aug 2006       08-15-2007, 10:45 PM Reply
You're a mad man those sub's are retarded monsters and huge dough. Did you get a hook up on it? Check out the stats on these guys. How bout the weight and mounting depth!
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Electrical Q Value -Qes: 0.460
Mechanical Q Value -Qms: 3.290
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Mounting Depth - 12.75
Mounting Hole Diameter - 11.5
Overall Diameter - 13
Bolt Hole Circle - 12.25
Motor Width -10.5
Motor Depth - 5
Basket Depth - 7.75
Displacement - .24 cu. ft.
Weight - 72 lbs.
Oh yeah and price on these is like $1200.00
Old     (macrogpx2)      Join Date: Dec 2005       08-15-2007, 10:57 PM Reply
Danny, what kind of boat are you putting that thing in?! I am going to UC Davis in the fall so if you are ever looking for a third, hit me up!
Old     (danny_h)      Join Date: Aug 2007       08-16-2007, 9:39 AM Reply
yea your right this sub is no joke its the real deal but . in the past i have ran over 5000 watts to one 18 but only for 30 seconds in a comp. its a friends centurion c4 .
Old     (grant_west)      Join Date: Jun 2005       08-16-2007, 2:59 PM Reply
how many inches is that?
A W-7 move's 3 inches 1.5 out and 1.5 back I thought it was 80 MM.
My math 54mm one way would mean 108 mm both way's
thats like 4 inche's WOW
What are you gonna power this thing with?
Old     (tdc_worm)      Join Date: Sep 2002       08-16-2007, 3:01 PM Reply
1 inch = 25.4mm,
54mm = 2.13 inches
Old     (grant_west)      Join Date: Jun 2005       08-16-2007, 5:55 PM Reply
BTW : I know RE makes a sub with the NEO magnet's I thought the one in the picture looked like it because of the smaller than traditional magnet size.
I would like to hear this and other RE sub's the spec's look real nice.
Old     (danny_h)      Join Date: Aug 2007       08-16-2007, 9:12 PM Reply
it should be playin in a few hours ill keep you up dated
Old     (bob)      Join Date: Feb 2001       08-16-2007, 11:07 PM Reply
Are you supporting the back end of the sub in the box. That thing looks like it would try to rip itself out of the hole in the box when hitting wakes.
Old     (danny_h)      Join Date: Aug 2007       08-17-2007, 9:30 AM Reply
ok i fired it up last night with one us amp md2d at 1 ohm is 1 x 1500 and it dumps but the speaker is not even moving so i need to strap one more md2d to it and then will see what happens yes the speaker has a brace for it .
Old     (grant_west)      Join Date: Jun 2005       08-17-2007, 9:01 PM Reply
I dont understand US amp's deal with RE Sub's. IMO US amps are pretty crappy amp's. And RE sub's are upper end sub's how or why would you pair a crappy week amp with a big power sucking sub?
Old     (ponte_06_x2)      Join Date: Jan 2006       08-17-2007, 10:05 PM Reply
because they can sell crappy amps, but they cant sell a lot of $1200 subs.
Old     (pickle311)      Join Date: Oct 2005       08-18-2007, 8:31 AM Reply
I bet it's not any louder than a Kicker solobaric or JLw7. It's still moving the same amount of air. Looks killer though and good job on the box. It should sound sweet.
Old     (nvsairwarrior)      Join Date: Aug 2003       08-18-2007, 2:34 PM Reply
Grant,
Which models from US do you have your "crappy" experience with? I only ask because I've been asked to audition some of their products.
sorry for hijack
Old     (wakeeater)      Join Date: May 2002       08-18-2007, 11:02 PM Reply
well if its moving 1 in more excursion wise compared to a w7 i would believe its pushing more air
Old     (grant_west)      Join Date: Jun 2005       08-19-2007, 12:52 PM Reply
Duane: I havent tested the US amp's myself so mabey I should have not said anything.
Why would you demo US amps when you sell ZAPCO now. IMO that like the Porsche dealer selling Yugo's
Old     (wake1823)      Join Date: Dec 2005       08-19-2007, 7:43 PM Reply
G, US amps are a well built highly regarded amp in the car audio world. They have different lines...their entry level aren't that great but there high end line is good quality.
Old     (danny_h)      Join Date: Aug 2007       08-20-2007, 12:22 PM Reply
ok us amps are not cpappy they are well built i would not say they are better than zapco but you can beat the crap out of them and they dont shut down the ax tube amp is off the hook .i have ran many diffrent anps in my life time and us amps are pretty good. and yes it is a lot louder than a kicker or jl if you ask me .
Old    deltahoosier            08-20-2007, 1:17 PM Reply
Danny your box needs to be tuned to 21 hz and should be 2.63 cu ft if you are running a ported enclosure. (not including the sub volume)
Unfortunately for you the box gods recommend using that sub based on it's mechanical and electrical qualities as a sealed sub. For a Q=1 you need a box that is about 0.51 cu ft (not including the huge volume for the sub) or for a Q or .707 you need a box volume of 1.27 cu ft.
Looks like right now you will more than likely not be able to get everything you want out of that sub.
(Message edited by deltahoosier on August 20, 2007)
Old     (nvsairwarrior)      Join Date: Aug 2003       08-20-2007, 2:57 PM Reply
Grant; Why audition US amps when I offer Zapco?
Good q but easy to answer.
1)Zapco is a bit pricy
2)Zapco does not allow Internet sales. My dealer agreement allows me to sell Zapco only as part of a system.
3)Certain situatins call for an amp not offered in the Zapco line. Case in point: Pair of JL W6 v2 (good), or NVS Alumapro RX (better). The Ref. line from Z does not offer a Class D. The 1100.1 is an A/B unit and is good but better for the application and $$ is available.
Lastly, like stated above, not to many Class A 12V units out there. That one is definetly on my audition list.
