Old    SupraSteve (suprasteve)      Join Date: Nov 2004       08-15-2007, 1:01 PM Reply
If you have 2, 4 Ohm speakers, and a 2 channel amp and you want to bridge the speakers onto the amp, can you do that and it still be a 4 Ohm load??
sound off...
Old    rG (canecorso)      Join Date: Aug 2007       08-15-2007, 4:28 PM Reply
No if you hook up in parrallel it will be 2 ohms or 8 ohms in series,
use this equation to find out omage; (1/ohm first speaker)+(1/ohm 2nd speaker) =; then (1/result)
your best bet without overloading the amp and/or speaker is to connect each speaker to each channel
Old    SupraSteve (suprasteve)      Join Date: Nov 2004       08-15-2007, 4:56 PM Reply
RG thanks for the input. I thought that it would probably be a 2 Ohm load(from the amps perspective) but wanted to get verification from someone who know's what their talkin bout.
I currently have it installed w/ each speaker as a channel on the amp.
Old    rG (canecorso)      Join Date: Aug 2007       08-15-2007, 5:24 PM Reply
No problem, its better to be safe than have a issue with overpowering/overheating which can melt the internal coil winding in the speaker or burn out one of the driver mosfets in the amp.
Is your amp only rated at max 4ohms?
