Hey all just thought I would join in and see if I can help....all the advice here so far is very good!! If I was to say what has helped people on my boat when I am teaching people here are a few things: 1) make sure that your handle positions is good, keep the handle low never higher then your chest, also keep i in a relaxed positions with your arms bent a little bit so the boat is not pulling you over the top of your board. 2) make sure that your hips are rolled forward (belly button to the sky) and shoulders back.....you do not want to be broken at the waist. 3) make sure that your knee's are rolled forward a bit you do not want to have your knee's locked...you do not have to have them bent alot but just a bit so you can use them as a shock absorber and suck up some of the chop and things. 4) And one that will help you on just carving or later on jumping if you choose, make sure that you are not looking at the back of the boat, always look shoreline to shoreline, when you turn left look at left shoreline, move the handle just a little bit to the left and look left you will go that way and on edge like you need to, it will be the same info for going to the right. I know this is alot of info but just try one thing at a time and progress that way....then do the next one.....you have to crawl before you walk right..... Have a good one...hope this will save you some pain!! T.
