Old                05-09-2001, 5:41 PM Reply
will staying on edge up the wake give me more air? someone told me that but i dont believe him....is this true?
Old                05-09-2001, 7:10 PM Reply
To get the maximum pop off the wake, you want to stay on your edge all the way up the wake, keeping the rope tight. This is called loading the line, what you do is build up tension in the rope. Staying on edge digs into the wake and produces a sling shot action when the board leaves the water. Anyway, stay on edge all the way up the wake.
Later
Tiffanator
Ladyboarder.com
AIM Suprachickchick
Thelandroi@yahoo.com
Hyperlite Wakeboards
XtremeGearOnline.com
Supra/Moomba
that should be Thelandroid@yahoo.com whoops
Old                05-18-2001, 11:29 AM Reply
If you go off your edge, you loose all of the load on the line you've worked so hard to build up. Stay on edge all the way to the top of the wake. You'll feel the pop.
Old                05-19-2001, 6:41 AM Reply
definitely, stay on your edge all the way into the air and even when you land. ultimately, you want to have the same body position from the time you turn in to the time you land and are edging out with the exception that you are just going to rise in your legs thru the top of the wake. it might take you a little while to get use to the load, but just keep your abs tight and your arms and chest still and see how much BOOT you get!
travis
ridethespot.com
