Old    Ren D. (want2ridealot)      Join Date: Jul 2007       07-28-2007, 11:51 PM Reply
I was wondering how everybody weighted their pre 05 VLX. Our set up is 400 in each locker, 500 stock in ski locker, and 200 up front in lead. O and we use the wedge too. I wouldn't mind having a smoother transition but still have the about the same steepness. I have not been able to really experiment with it because it is Dad's boat. I will post some pics when I get them.
Old    Ren D. (want2ridealot)      Join Date: Jul 2007       07-29-2007, 5:40 PM Reply
bump
Old    Ren D. (want2ridealot)      Join Date: Jul 2007       07-30-2007, 7:40 PM Reply
no one
Old    Tracktor (tracktor)      Join Date: Sep 2005       07-30-2007, 9:52 PM Reply
500 in each locker
400 in ski locker
400 on walkway (probably a bit less bag is squeezed)
200 lead in nose
No wedge
I would try no wedge. It adds the lip at the top from my experience.......
Old    MIKE O (batman)      Join Date: Nov 2001       07-31-2007, 8:08 PM Reply
Tracktor has the setup. I had an 02 and 04 VLX and usually did not use the wedge.
Old    Greg Miller (g_miller)      Join Date: Dec 2002       08-01-2007, 9:02 AM Reply
98 Sunsetter VLX
750's in rear lockers
4 or 500 in ski locker
750 from walkway to rear
160 lead in nose
no wedge
3 to 4 people.
If we have more people we put less or no weight in the walkway.
Old    Greg Miller (g_miller)      Join Date: Dec 2002       08-01-2007, 9:05 AM Reply
Sweet boat tracktor. What year is it?
Old    Hate2party (slipknot)      Join Date: Aug 2001       08-01-2007, 9:11 AM Reply
Heres is what I ran in the 2001 WSVLX:
750's in the rear, center MLS (400), and 300 lbs of lead in bow no wedge.
The 2004 WSVLX is running the wedge , 400's in the rear, center MLS (400), 300 lead in the bow. I am switching to the ProX 700's for the rear since I just won a $1000 gift certificate from the NMMA.
Old    Someone Else (deltahoosier)      Join Date: Jun 2002       08-01-2007, 9:16 AM Reply
I had stock ballast in the back which was 400 pounds if I remember correctly. 500 center ballast stock. about 200 in each locker. Around another 400 or 500lbs or so in the front of the boat and the wedge.
Old    Tracktor (tracktor)      Join Date: Sep 2005       08-01-2007, 10:38 AM Reply
Greg, it's a '98 also. Thanks for the compliment. Yours is looking good too.
As a side not, I switched to an OJ 475 prop with excellent results weighted & unweighted........
Old    Greg Miller (g_miller)      Join Date: Dec 2002       08-01-2007, 11:19 AM Reply
I just switched to an Acme 1235. HUGE difference!
My top end is about 42 now but who cares, I never drive much faster than 30 anyway.
Old    Pete Mann (juiced4ever)      Join Date: Oct 2005       08-01-2007, 12:05 PM Reply
I had on 02 vlx and this is what i stuffed in it.
I put 250 in lead on top of the 250 ballast tanks on each side of the motor
fill the center sac which is 400-500 pounds
i had a 2 440 lb sacks on the floor one in the walk way and one infront of the rear seat.
And a 350 up front.
No wedge (broke to many of them) plus the boat drives better with out it. All in all it is a solid wake.
Old    Beecher (wake175m5)      Join Date: Jun 2007       08-01-2007, 8:47 PM Reply
we are in a 2001 air
440 each locker
750 on the floor against the back seat
600 under the floor in the ski locker
6 or 650 in the bow
we havent messed around with it much,,,what do people think?
Old    Someone Else (deltahoosier)      Join Date: Jun 2002       08-01-2007, 9:28 PM Reply
Here is the wake at 70 feet back at 24.7 mph.
Old    Ren D. (want2ridealot)      Join Date: Jul 2007       08-02-2007, 12:08 AM Reply
Today we rode behind our 02 VLX. With 400 in each locker, 500 center, 200 lead and 9 people and the wake was the biggest I've seen it. Rod 24.7!! We have never had to go that fast, who much weight did you have. We usually go 22.5 or 23 with people.
Old    Ren D. (want2ridealot)      Join Date: Jul 2007       08-02-2007, 12:09 AM Reply
O has anybody tried putting a bigger sack in the locker?
Old    Greg Miller (g_miller)      Join Date: Dec 2002       08-02-2007, 4:38 AM Reply
Ren,
The sack I have in the locker will hold around 6 to 700# but the locker will only hold 4 to 500#.
Old    Dtb (dtb)      Join Date: May 2002       08-02-2007, 7:29 AM Reply
2000 VLX - I run the factory MLS in the ski locker, 600's in the back, and put another 600 in the walkway, but it doesn't fill all the way (maybe 400 lbs), beyond that its just the more people the better. I'm thinking I need a new prop. Greg, is the ACME 1235 the way to go?
Old    Someone Else (deltahoosier)      Join Date: Jun 2002       08-02-2007, 1:48 PM Reply
Ren, I discribed it in the above post. You may not ride that fast but you are also more than likely not 300 lbs like me either lol. I have since sold the boat, but, I have towed every kind of rider from kids to pros. The advanced guys all ride fast and long than I have been around. I used to ride at 23.7 but my board would sink a bit. I finally took the speed up to where I can be riding directly behind the boat and I can actually pull on the handle and my board will advance forward. If you are riding slow enough that the board is sunk then you will not be able to advance the board without pulling on it like a tug of war. That is my start point and that is around 24.5 to get to that point. That allows my board to have crisp edge to edge response and do things like little ollie blind 180's in the flats and things like that. SOmetimes if I have not rode in awhile I will ride at 23.7 to get my sea legs back. So, that is how I approach it anyway.
Old    Tracktor (tracktor)      Join Date: Sep 2005       08-02-2007, 3:30 PM Reply
Rod, you bring up an interesting point about speed. This may not be on topic, but....I have my VLX and my Buddy has an '05 X-2. We weight them pretty close poundage wise, placement is a bit different. We ride at 24 behind the X-2 and 22.5 behind my vLX, GPS verified. If we ride 24 behind mine it seems way fast and vise versa with his. Just thought that it was interesting how different hulls effect ride.........
Old    Someone Else (deltahoosier)      Join Date: Jun 2002       08-02-2007, 5:43 PM Reply
You may be getting influenced by wake width or something. Can imagin that the same GPS speed with different boat can affect you. Usually with a wake width difference I change line lengths because speed is speed with my board sinking or not. You may have verified speed running normal speeds with the boat plained out but when boarding the boat is not plained. THat will affect the water running over the speedos and can change calibration. I have not verified that but I can see that as a possibility.
Old    Greg Miller (g_miller)      Join Date: Dec 2002       08-02-2007, 7:05 PM Reply
DTB, Yea, the 1235 is the best thing I've ever done to my boat.It seems a little expensive but its well worth it. propellersonline.com is the cheapest place to get it.
Old    Dtb (dtb)      Join Date: May 2002       08-03-2007, 5:50 AM Reply
Thanks Greg. I haven't done much research on props, is the 1235 going to be the same diameter as my factory prop? I only have about 1/4 inch of clearance from the trailer prop guard as is....
Old    Cliff (ord27)      Join Date: Oct 2005       08-03-2007, 7:53 AM Reply
mine still clears the prop gaurd on the trailer
I have a Dorsey trailer
it does seem a little closer, but haven't had any issues
Old    Greg McNeill (greg2)      Join Date: May 2002       08-05-2007, 2:56 PM Reply
I have a larger sack in my locker and it is only around 400 lbs on the scale.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       08-05-2007, 10:07 PM Reply
Greg Boarditup.com has the 1235 cheaper than propellars online fyi..
