Old    Zach (zacharoo)      Join Date: Nov 2005       08-01-2007, 12:10 PM Reply
This is my swim platform's best day. TeakGuard is the product that I used and I was SHOCKED at how it turned out.
BeforeUpload
DuringUpload
SandingUpload
Prior to Super CleanerUpload
Old    Zach (zacharoo)      Join Date: Nov 2005       08-01-2007, 12:16 PM Reply
After Super Cleaner and wetUpload
Pic of how clean and notice no oilUpload
First coat Teak GuardUpload
Second coatUpload
I'll put two more coats per the instructions but wow the look is great. It got a UV blocker in it and is suppose to last a year of usuage. Only time will tell.
Old    dustin sahlmann (dnice)      Join Date: May 2006       08-01-2007, 12:20 PM Reply
Where did you get it? Mine needs some major work as well!
Old    Dennis (denwbaseball)      Join Date: Apr 2007       08-01-2007, 12:41 PM Reply
How long do you have to wait between coats, and getting it back in the water?
Old    Zach (zacharoo)      Join Date: Nov 2005       08-01-2007, 12:42 PM Reply
Saw it on the web and ordered it after talking to owner about what it does. I have used various othr products but this looks like it a winner.Do a search for TeakGuard. You'll find it no problem.
Old    Zach (zacharoo)      Join Date: Nov 2005       08-01-2007, 12:52 PM Reply
15 minute between the first 2 coats. I have to wait a day to put the last to coats. Once its dry in the water it may go. The stuff is a "polymer resin base that allows moisture to escape by breathing through the finish. Uses combination of of UV block and reflectors to potect teak....will not allow mold or mildew to grow blaa blaa blaa"
Old    Jon (jon4pres)      Join Date: May 2004       08-01-2007, 1:06 PM Reply
You did a great job sanding and cleaning. That is where you get the results.
I used Starbrite and got a similar result but only because I spend hours sanding it.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       08-01-2007, 3:21 PM Reply
I used Starbrite on mine with no sanding and had great results.
Old    baine (abhoe157)      Join Date: Feb 2007       08-01-2007, 3:31 PM Reply
I second Starbrite. Our teak was looking a little gray for some reason so i took it home one weekend and it didn't take much time or effort to get it looking brand new.
Old    bobby m (bobbym)      Join Date: Dec 2005       08-01-2007, 4:50 PM Reply
I teakgaurd my platform every two years.
If not for some scrapes from board fins, I would get much longer inbetween coats.
Just touching up the scrapes doesn't protet as much as a full cleanup and application.
Old    Bryan (westsiderippa)      Join Date: Dec 2006       08-01-2007, 8:39 PM Reply
great job!!! looks perfect. i remember thoughs days. had to do the same thing when i bought my first nautique. i will share a little tip i was given, after i finished cleaning up my swimstep and applied all the teak oil and stain etc. because the price of teak oil was fairly expencive at the time for me. i would rub a thick coat of vegi oil on it after every use. worked great. just a cheaper thought for maintnace. looks great though
Old    Scott Bilyeu (sbilyeu)      Join Date: Jul 2007       08-03-2007, 4:36 PM Reply
Yeah, teak oil is great for 2 things, great looking swim deck and eatin' sh*t after a few beers!
