Old    Frank Delgado (boardnmoto)      Join Date: Aug 2006       07-27-2007, 12:25 PM Reply
Can anyone show me some pictures or tell me how the Sky Supreme ballast system works and if they have any issues with this setup. I want to install a similar ballast setup in my 2003 Supreme V220SP. Any suggestions on the install would be helpful as well. I've found a lot of good information on WW.
thanks
Old    HeHateMe (hamkj)      Join Date: Apr 2002       07-27-2007, 1:43 PM Reply
Hey Frank.
I have the following.
Two standard hard tanks in the rear two lockers. They came stock.
Then I added two more 750lbs bags on top of those.
And in the bow I have two 600lbs under the front seats... and a 500 under the bow filler cushion.
I use the Jabsco Ballast Puppy pumps.. which you will read some have had a lot of problems with them... but I have been pretty lucky.
I built two manifolds for them. So I can fill or empty each sack or tank.
Total weight approx 3500-3800lbs.
Changed prop to acme 3 blade 10.5 pitch... out of the hole and holds speed no prob!!!!
I will be moving my pumps to underneath the back seat with impellor access facing inside the boat... make for easy in and out changes...
Old    Frank Delgado (boardnmoto)      Join Date: Aug 2006       07-28-2007, 7:45 PM Reply
Wow now that's some serious weight! I bet your wake is huge! Do you have to flip any valves with the stock ballast? What does your manifold look like?
thanks for the response.
Old    Shawn Hammond (eargasm)      Join Date: May 2007       07-28-2007, 7:49 PM Reply
Frankie, I wanna see you roll 4,000lbs. in that thing. We'll be calling you for pulls every weekend.
Old    Frank Delgado (boardnmoto)      Join Date: Aug 2006       07-28-2007, 8:21 PM Reply
I had 2000 lbs in it today and the wake was freakin huge. My wife was driving and she said it was a big fat pig. Then we drained the ballast and she ripped my arms out. I'd be divorced if I was pushing 4k.
Old    Maddy (maddy)      Join Date: Jul 2007       07-28-2007, 8:28 PM Reply
Oppps - my bad
Old    Jonny (wakeboardlasvegas)      Join Date: Mar 2007       07-29-2007, 12:25 AM Reply
you never got on plane cuz that boat with any motor cant do it
honestly, supremes have a wake like most super air when weighted. those boats NEED weight in the bow for sure.
Old    Maddy (maddy)      Join Date: Jul 2007       07-29-2007, 10:24 AM Reply
How much weight should I put in front to balance it out. I had the ProX V drive sacks (400lbs ea.) and I put 150 lbs of lead in the front. My passengers wanted to hang out in the back seat, so that was another 350lbs.
Old    Frank Delgado (boardnmoto)      Join Date: Aug 2006       07-29-2007, 1:07 PM Reply
My bad my wife was logged in on the previous post. Does anyone have any pictures of the Supreme v220 setup.
Old    B Poser (bbr)      Join Date: Apr 2002       07-29-2007, 3:15 PM Reply
Lets see some pics of the wake!!!
Old    Frank Delgado (boardnmoto)      Join Date: Aug 2006       07-29-2007, 6:30 PM Reply
I'll have to take some pictures next time we go out. I'm going to add more weight to the front to see if I can balance it out some more. The wake was pretty nice except we had to ride at 25mph
Old    Waylon (wayz)      Join Date: Jun 2005       08-03-2007, 9:47 AM Reply
I'm running with 400 lbs. in each rear locker on top of the stock ballast, putting it at 1400 lbs in the rear. I also have the 700 lbs sack in the bow underneath the seats.
Old    Miguel (migs)      Join Date: Aug 2006       08-03-2007, 2:28 PM Reply
Heres mine. internal ballast, fat buddie in each rear locker, big fat boy in the bow, fat buddie in the bow walk way, one big fat boy on the floor parallel to the rear bench.
Old    WakesetterLSV (closedtoe)      Join Date: Jan 2007       08-03-2007, 4:01 PM Reply
Anyone got pics. I'd really like to see one because there isn't too many sky supreme 220 wake pics floating around
Old    Miguel (migs)      Join Date: Aug 2006       08-06-2007, 7:34 AM Reply
ill take one next time im out.
