Old    Dave (deltadave)      Join Date: Mar 2005       07-24-2007, 3:00 PM Reply
I was talking to a guy briefly at the launch ramp and he said he runs a Boston Acoustic 1 ohm amp for his 4 tower speakers and 1 ohm is the way to go. What do you think? If I go 1 ohm, which brand?
Old    Matt (loudsubz)      Join Date: Aug 2001       07-24-2007, 5:27 PM Reply
1 ohm is not the way to go...and anyone will say anything to impress the guy next to him
lower impedance means amp is flowing more current and is creating more heat so it is not the best for the amp. He may be running it at 1 ohm to get more power from it, but a more powerful amp running at 4 ohms, running cooler would be a better way to go.
Old    Clubmyke (clubmyke)      Join Date: Aug 2004       07-24-2007, 10:51 PM Reply
does ba make a 1 ohm full range amp ?
i dont know for sure, but i seriously doubt it...
Old    Taylor Jensen (wakeboardertj)      Join Date: May 2005       07-25-2007, 1:02 AM Reply
i'm no expert but i think the only amps for car/boat audio that are run at 1 ohm are amps for subwoofers,
Old    Rich (rson)      Join Date: Jun 2002       07-25-2007, 8:27 AM Reply
I have seen half ohm stable amps....the Hifonics Ulysses was a 1/2 ohm stable.
It would put you in a 50 watt class for competition but in reality you would be running 200x2 at a .5 ohm.
Old    Rich (rson)      Join Date: Jun 2002       07-25-2007, 8:30 AM Reply
I doubt BA has a 1 ohm stable amp...in fact I would call BS if you see that guy again.
Old    Clubmyke (clubmyke)      Join Date: Aug 2004       07-25-2007, 3:29 PM Reply
there arent too many 1/2 ohm "cheater" amps around... the lowest you would ever want to go is 2 ohms...
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-26-2007, 11:14 PM Reply
Assuming each speaker is 4 ohm there are lots of options, setting it up to run on a 1 ohm load is pretty far down on my list.
There are plenty of good four channel amps, a few big two channel amps that push 2 ohms/channel, you can mix and match series speakers and bridged amps if you want to save on tower wiring too.
Running 1 ohm with our somewhat low boat battery voltages causes most amps to run quite hot and inefficient.
