Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old    brandon (bdoggvtec)      Join Date: Jul 2007       07-09-2007, 7:47 AM Reply
i have a 1994 nautique correct craft, something is not working correctly with the starter. i replaced all the fuses, and i kepp getting voltage intermittently through the wiring! is this a problem with starter relay? ignition relay? the boat won't start. thanx!
Old    B. Eriksen (scanboarder)      Join Date: Feb 2005       07-09-2007, 12:35 PM Reply
tried bypassing the solenoid? just connect the two points with a piece of wire.
Old    Peter_C (peter_c)      Join Date: Sep 2001       07-09-2007, 2:41 PM Reply
"i kepp getting voltage intermittently through the wiring!'
What does that mean? Often the relay on the back of the block fails. They are a special marine solenoid though. Most auto parts stores carry or can get them.
You need to test the voltages at the relay and at the starter directly.
