Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old    John (johnson0505)      Join Date: Jan 2006       06-25-2007, 9:48 AM Reply
I need ideas on how to cut the power from the battery to the amp ? I bought boat used and its wired straight from battery to amp and killing battery.
Old    Stan Tanner (sbt3)      Join Date: Jun 2002       06-26-2007, 7:07 AM Reply
There should be a remote wire on the back of the stereo (blue wire) that you tie the remote input on the amp to. This will shut off the amp when the stereo turns off.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       06-26-2007, 7:46 AM Reply
John, sbt3 idea should work , but a fail proff way is wire in a circuit breaker on your main power wire. problem solved.
Old    Rich (rson)      Join Date: Jun 2002       06-26-2007, 8:00 AM Reply
Perko switch or inline breaker. You can fix it yourself by running a remote wire to the back of your radio. There should be a blue wire labeled Remote or Amp. Connect the amp to that via small wire and then when the radio turns on, the amp comes on.
