Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old    Len Cast (lencast)      Join Date: Jun 2007       06-22-2007, 6:19 PM Reply
Apparently, while beached at Folsom Lake, my prop hit 1 too many times. All the traffic slammed it repeatedly into the sand. "They" say that it's a problem w/ the transon seal. Do I really have to get the engine pulled out to fix this? Not to mention, an estimate of 3 weeks & 1200 bucks! I'm screwed...right?}
Old    Nate (norcalmalibu)      Join Date: Jun 2004       06-22-2007, 8:12 PM Reply
what exactly is leaking? Transon seal as in the shaft input seal?
Old    Len Cast (lencast)      Join Date: Jun 2007       06-23-2007, 12:46 PM Reply
yes, the transom seal has a breach somewhere.
Old    Trace (trace)      Join Date: Feb 2002       06-23-2007, 2:07 PM Reply
What is a "transom seal"? There is no such thing. If it's from being pounded on a beach, my guesses are the rudder is leaking, or you bent your prop shaft and it's causing the shaft seal to leak.
Old    Charles (chas)      Join Date: Feb 2002       06-23-2007, 3:01 PM Reply
If it is an outdrive it could be leaking around the transom seal. Gasket like between the transom and the outdrive itself.
Old    Trace (trace)      Join Date: Feb 2002       06-23-2007, 4:51 PM Reply
Ah, yeah, his profile says he has a Reinell... That had to be a hell of a beating to cause a leak there, there may be damage to the 'glass or the gimbal mount.
Old     (nbeihl)      Join Date: Mar 2004       06-23-2007, 4:56 PM Reply
I had an inboard/outboard a long time ago and when we had the transom seal leak it was a little over $1,000. That is one good thing about the good ol' inboard... There is no transom seal!
Old    trey mclendon (tdiggity)      Join Date: Dec 2006       06-23-2007, 8:43 PM Reply
yes to fix a transom leak on an inboard/outboard you have to pull the motor, if its coming from the the bolts running through the outdrive. check the bead of silicone running the perimeter of the housing around the outdrive if its popped up anywhere that means its shifted and your leaks coming from there or the bolts running through the transom itself.
