Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-11-2007, 5:59 PM Reply
I don't know my problem but every time i try it i fall on my face? I have seen 1 video and got insructions from here and neither worked! any help would be nice.
Old    Justin (jusstty)      Join Date: Dec 2006       06-11-2007, 6:01 PM Reply
A video would help?
Old    Pottsy (pottsy)      Join Date: Jul 2006       06-11-2007, 7:01 PM Reply
usually when u fall on your face you either clip and edge or you pull the rope in too far. So just relax and lean back and bend your knees a litle bit and make sure you dont pull on the rope and you should be fine
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-12-2007, 5:25 PM Reply
thanks, and i can't get a video. sorry.
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-15-2007, 12:28 PM Reply
i'm gonna try that tomorrow, but any other advice?
Old    Brandon Kee (trickyboarder08)      Join Date: Jul 2005       06-15-2007, 3:03 PM Reply
Don't lean back too far. Thats what i was doing at first. It is really easy, just relax bend your knees and turn. It also depends on the board you have. I have a Shane board and it is so smooth the turn on, but my old obrien was a bitch to get turned.
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-16-2007, 5:01 PM Reply
i have an obrien 138 oasis from 2006
Old    Donald Hill (dh03r6)      Join Date: Mar 2007       06-20-2007, 11:28 PM Reply
take any fins off
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-24-2007, 1:40 PM Reply
okay i will try that
Old    Steve (crack)      Join Date: Sep 2006       06-24-2007, 2:38 PM Reply
Assuming your regular foot...just pull the handle to your right hip and lean back a bit. I heard that somewhere and it helped me.
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-24-2007, 8:41 PM Reply
Do i have to take the fins off
Old    Justin (jusstty)      Join Date: Dec 2006       06-25-2007, 10:55 AM Reply
Just move the handle to your opposite hip.
Old    kal schultz (kal_dude)      Join Date: Apr 2006       06-25-2007, 2:31 PM Reply
keep your weight on your heels!!! unless you want to faceplant??????????
Old    Justin Mohlke (wakekid72501)      Join Date: Jul 2006       06-25-2007, 4:11 PM Reply
again do i have to take the fins off
Old    Soli (nsolis220)      Join Date: May 2007       06-25-2007, 4:16 PM Reply
no fins on is fin its just a weight transfer forward some and like the other guy said take the handle to the other hip. it also helps me sometimes when i was learning to edge some when switching back to reg
Old    Brennan (afrodeziak)      Join Date: Apr 2002       06-25-2007, 5:12 PM Reply
when you do a water start, try to keep your board in a 90 degree and ride as long as you can, should give you the balance to do surface 180's and be comfortable.
B..
surf the wake a bit and use the wake as a tool.. butterslide then let go with the front hand.. back in the day when i had huge fins and couldnt'do surfaces 180's I'd always use the wake for it..
Old    dj (rivrrunr)      Join Date: Feb 2005       06-26-2007, 6:40 PM Reply
i learned surface 180 by doing them as soon as the boat pulls you out of the water. the low speed and agitated water just makes it easy. then try them on top of the wake. your fins will break loose easier on the crest of the wake.
