Old    Chris Weiland (mracrew)      Join Date: Apr 2005       06-20-2007, 7:50 PM Reply
I have landed a few but most of the time i land nose heavy and eat it. I do have a little trouble passing the handle but when i really concentrate on getting it i do. here is a link to my attempts http://www.youtube.com/watch?v=xjtQzrLWVlc
Old    alan plotz (alanp)      Join Date: Apr 2001       06-20-2007, 9:28 PM Reply
chris i would take a much mellower cut, only go wake to wake at first then take them into the flats. you'll have alot less line tension therefore youre not gonna get pulled over(lose your axis) and the handle pass will be easier. also i would hold off on the grab. seems like youre attempting to do to many things, a 3, into the flats, with a grab. learn the 3, then the grab, then go out into the flats.
my guess is your probably gonna keep attempting the 3 like you are so, pull the rope a little harder to create more slack and lean a little further back(away from the boat) this will set your axis a little better.
