On the fill lines or the empty lines? Or are you using a 2-way pump so the fill and empty lines are the same line? If it is only on the fill lines, then what Chris said is true. Just get some cheap $3 check valves at Home Depot and pop them in the middle of the line. If you are also siphoning out through the drain lines (like I was on my Malibu) you will need to buy some electronically-actuated valves that open when the drain pump is turned on. I got some from STC valve Co. in California for about $60 each.
