Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old    Steve Amestoy (stevev210)      Join Date: Feb 2005       06-17-2007, 11:37 AM Reply
Im sure the CIE crew, Big Ed and Gordon can help me on this ?. What prop do you guys run on the x2 when running 2k or more of ballast?
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-17-2007, 1:37 PM Reply
I run my original stock prop and still do....after almost 400 hours put on it in the Delta.....pretty lucky if you ask me!
Gordon runs a 1235 but from what I understand(gordon told me)If I wanted the same prop,it would be a 1234.Same prop but different mount.I guess it changed from his 2001 pro star to my 04.
When I run 3-5 people and 2000lbs.....no problems,maybe 4 seconds till plane time.Add another 1000lbs....I'm looking into 7-9 second plane time(depending on the conditions)I guess that is still not bad but at that point a different prop would be nice.IMO
Old    Steve Amestoy (stevev210)      Join Date: Feb 2005       06-17-2007, 1:55 PM Reply
Thanks Ed! My friends is a 05, we were out yesterday with 5 adults 2 kids and 1300lbs ballast and it seemed like it took forever to plain out. Im sure it would be a 1234 for a 05 also.
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-17-2007, 3:03 PM Reply
stern heavy??
Old    Steve Amestoy (stevev210)      Join Date: Feb 2005       06-17-2007, 6:38 PM Reply
500lbs in rear, belly sac plus 400lbs in popbags in nose.3 adults in bow, me driving another adult in passenger seat and two children in back.
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-17-2007, 9:19 PM Reply
500lbs in the rear meaning just the stock tanks or plus the stock tanks?
if you had JUST the stock tanks....then something is wrong.You should be jumping out of the water.
If you had extra 500lbs in the back...then you guys were stern heavy and need to move some weight up front.
hmm...1,300lbs over stock or all together?it does make a difference.
Old    Steve Amestoy (stevev210)      Join Date: Feb 2005       06-17-2007, 9:27 PM Reply
500lbs total in rear just the 2 hard tanks. Belly sac plus 400lbs of popbags in bow. 1300lbs total ballast. Plus peeps. Heck maybe the previous owner didnt even have the stock prop on it cuz it took a while to plain out. I think he'll still want to upgrade to the 1235 cuz hes gonna swap out the tanks for the 400lb flyhigh vdrive sacs.By the way, my brother thinks your wake is sic (Trevorcentralcali)
Old    Marco (macrogpx2)      Join Date: Dec 2005       06-17-2007, 9:27 PM Reply
what are the dimesions on your stock prop big ed?
Old    Greg Bodor (gti2lo)      Join Date: Nov 2005       06-17-2007, 10:13 PM Reply
Something sounds fishy...
I have factory ballast... 500 in rear, belly tank (fly high) and 6 people... pop'd right out of the hole.
I have stock prop on a 06 X-1 with the RTP-1 engine.
Old    ejojprop            06-18-2007, 4:50 AM Reply
14.25 X 14 LC OJ XMP EDGE or 14.25 X 14.5 OJ XMP EDGE. Both of these propellers are stock on MASTERCRAFT depending on the motor. What motor do you have and what year is the boat?
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-18-2007, 8:33 AM Reply
Only if I lied would I be able to tell you my size/pitch of my stock prop.I have a MCX and 2004 X2.
Steve,something is wrong,I sometimes have 1,3000lbs over stock and no problems planing out.Thanks and tell your brother I said hi,btw how is the knee?
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-18-2007, 8:35 AM Reply
Ohh my boat is in Disco bay and I'm in LA so I can't check.
Old    Gordon (rake)      Join Date: Jun 2003       06-18-2007, 9:13 AM Reply
Steve,
As Ed pointed out, I run the 1235 (14.5" x 14.25P)with the RPT-1 motor and have no problems with 3k+ ballast, 4k+ it takes a few seconds to get on plane but no problems, any more ballast than that and the boat is real low in the water. For I think it is 03 and above, Mastercraft went with the splined shaft which would be part number 1285 (not 1234, which is RH rotation).
Lost a bit of top end but since I ride the dirty D, there is not a lot of just cruising time and the hole shot is worth it, the boat comes out of the hole and on plane effortlessly. With no ballast you have to be easy or you'll tear the arms off a beginner.
Paul Brothers who posts on here did a write up on OJ's product the edge which he is running and seems happy with. You can also talk to with Bill Weeks at ACME (www.acmemarine.com) and he'll set you up with the right prop for your application.
Awesome boat and my favorite wake. Next time you're up here we'll head out.
Gordon
