Old    HeHateMe (hamkj)      Join Date: Apr 2002       06-15-2007, 11:07 AM Reply
I am just in the midst of designing a deck I can put over the boat when trailering so I can take the following:
2 - Dirt Bikes
1 - ATV
3 - Mountain Bikes
Some camping gear.
My trailer is tandem axle with 3700lbs rating each.
My boat is 3000lbs. So I am assuming as long as I have the weight centered over the axles that I should be okay with an additional 1200lbs.
My idea is to build a light weight (frame with mesh)deck. That can be easily lifted by two people. Back mounts will slid onto boat guides and I will make similar boat guide posts in front of the axles... Quick release pins... and some long ramps.
Then when I go camping... I can take the camper... and all the toys...
To avoid modifying the trailer... I will use u-bolts etc... to add the new boat guide mounts.
Visually... it looks like it will work no problem... since the atv/dirt bikes will be sitting directly over the axles.
I would love to do something like in the picture.. but the wakeboard tower is the issue.
Old    John Schneble (john30)      Join Date: Nov 2003       06-16-2007, 3:21 PM Reply
When I was originally in the market for a boat I saw a Malibu with an overhead bunk for a sit down jet ski. I think one thing to take into consideration would be the height of a standard overpass and such. Good luck with the project. Make sure to post some pics of it.
Old    Tyler McCurdy (tyboarder03)      Join Date: Nov 2003       06-16-2007, 3:27 PM Reply
Just drop the tower and go at it... if its removable just put the tower up when you unload everything else and take the top off.
