Old    Chasin7 T (chaser)      Join Date: Sep 2006       06-10-2007, 8:08 PM Reply
Where does all the water come from that is in my ski locker of my 2002 X-star? I took out about 3 gallons from there today. There was very little in and out of the boat today and I never filled the ballast in the ski locker so I'm sure that's not leaking. does water from the bilge area make it's way up there through the openings that one of the ballast hoses comes through? Thanks
Old    Lionel (lionel)      Join Date: Nov 2005       06-10-2007, 8:55 PM Reply
"does water from the bilge area make it's way up there through the openings that one of the ballast hoses comes through?"
Yes......
Old    Clint (ttuclint)      Join Date: Sep 2003       06-10-2007, 9:56 PM Reply
do you have a heater ?
If the water is real warm in there it's leaking out of the busted heater.
Old    Torey (wake4chicks)      Join Date: Oct 2006       06-10-2007, 10:38 PM Reply
did u put the plug in???
Old    Mikeski (mikeski)      Join Date: Aug 2003       06-10-2007, 10:41 PM Reply
Did you dip the nose or take anything in over the back?
Old    Chasin7 T (chaser)      Join Date: Sep 2006       06-11-2007, 6:23 AM Reply
no heater. Did not dip the nose. Yes the plug is/was in.
Old    LarryW (h2omantx)      Join Date: Jan 2007       06-11-2007, 10:14 AM Reply
Check the shaft seal where the shaft goes down through the hull. You may need to tighten it or repack it with wax rope (able to purchase at any marine shop or boat dealer). Normally it should have a few drops of water coming through but not much. If the seal (wax rope) is worn out you can get a stream of water coming through there.
Old    leonard araujo (laraujo)      Join Date: Apr 2007       06-11-2007, 1:51 PM Reply
I have noticed the same thing. I am having mine repacked currently. Hope it works! I noticed mine seems to take on water more when I am running not so much just sitting. Is that usually the situation for a poorly packed seal?
Old    KG (iagainsti)      Join Date: Apr 2004       06-11-2007, 3:28 PM Reply
I had the same issue with my 01 X-star. Have you checked your center sack for leaks or tears ? My bag(blue)tore at the seam.
Old    Chasin7 T (chaser)      Join Date: Sep 2006       06-14-2007, 11:05 AM Reply
I have a yellow sack. I did pull the sac, twice now thinking that was it. But it seemed fine. I haven't checked the seal for the shaft yet. Weird cause I was out today for about 3 1/2 hours with ballast tanks/sac full and 6 people in and out of the boat and there was hardly any water in it this time? Last time when I noticed all the water, we were out for probably 6 or so hours, most of it just beached on a sand bar laying around. NO ballast filled.
Old    Billy (woreout)      Join Date: Aug 2006       06-14-2007, 11:25 AM Reply
My sack is sometimes purple, but I still check it from time to time. I never get leaks around the seal of my shaft, however my shaft does seem to leak out the end.
Old    WakeShoe (wakeshoe)      Join Date: Jun 2004       06-14-2007, 11:40 AM Reply
Billy,
Didn't you say that Parks' shaft leaks near his purple sack from where the alligator bit him??
(Message edited by WakeShoe on June 14, 2007)
Old    Billy (woreout)      Join Date: Aug 2006       06-14-2007, 11:45 AM Reply
Yes, that gator was nuts.
