Old    ryan jensen (trx1noob)      Join Date: Sep 2006       06-09-2007, 7:10 PM Reply
any of you have any experience with wiring new switches into the boat. On my 07 enzo, when I pull out stock switches for current ballst, there are a couple of spare black boxes wired in line with the current switch. can I use these for power for my new switches? thanx
Old    Team CBK....Nate (cbk)      Join Date: Aug 2006       06-09-2007, 8:02 PM Reply
Ryan - I am sending your switches and thru-hull drains Monday....I wish I lived closer so I could surf behind that Monster!
Old    ryan jensen (trx1noob)      Join Date: Sep 2006       06-09-2007, 8:30 PM Reply
nate, sounds good buddy. do you have the wiring diagram for the switches once i get them?? can i just tap into the black boxes on the backside of the current switches. thanx
also, what do you have for the youth bindings in stock?
Old    Nashville (dubguy72)      Join Date: Jul 2006       06-09-2007, 10:23 PM Reply
go to the website and email warrenty or parts they can send you all that info
Old    Team CBK....Nate (cbk)      Join Date: Aug 2006       06-10-2007, 8:38 AM Reply
Got some really small Gator bindings..I think they will work for youth. I don't think there are any diagrams, but you can call Fineline West and they can guide you.
Old    ryan jensen (trx1noob)      Join Date: Sep 2006       06-10-2007, 3:38 PM Reply
hey nate, just took the battery off my makita drill and did some testing. there are 5 prongs on the switch. one side has 3, other side has 2. i found out that the middle prong on 3 side is the power. and the other 2 on that side are power for the pumps. the other 2 prongs i'm guessing i tie into the power on the 3 side, and they are for the back lighting on the switch itself. I think i'm set to go. I'll take a power tester and test those black boxes already in there and see if there is power coming from them. thanx for any input. ryan
Old    Kevin R Baugh (krbaugh)      Join Date: Mar 2002       06-10-2007, 4:59 PM Reply
What kind of pumps are you using? How many amps?
Old    ryan jensen (trx1noob)      Join Date: Sep 2006       06-10-2007, 9:39 PM Reply
hey kevin, tsunami 1200 gph for filling(i believe 6 amps) and 800 gph for draining(4 amp i believe) I've got a 30 amp fuse in between switch and power that i've tapped into. wired everything up and seems to be working great. time to go test it. I'm a little nervous, hope she dont' sink.lol I've rechecked every connection, I'll have someone with hand on through hull valve ready and waiting. now that i've done one, It's a fairly simple process.
