Old                04-28-2001, 8:12 AM Reply
when ur in the air for a hs 3, do u pull the handle in to ur hip slowly, or do u jerk it in...an once u got the handle behind ur back, does the momentum carry u through, or do u pull the handle again to get around?
Old                04-28-2001, 8:51 PM Reply
fronside or backside?
Old                04-30-2001, 2:19 PM Reply
backside
Old                05-22-2001, 11:31 AM Reply
As you are going up the wake pull the handle in at the same time, but don't start to spin until you leave the wake. Works for me....
Old                06-01-2001, 3:06 PM Reply
I dont know if you're having problems with the handle pass or not but when i started trying them I would always freak out halfway thru the trick and throw the handle. What helped me out was realizing that I had way more time than i thought i had. Think about almost wrapping into the rope.. that will make the handle pass easier.
brian
Old    labambacho (junk) on Fri            06-08-2001, 1:54 PM Reply
Go FAST Go FAST GO FAST. SHARP TURN> spread them.
jump in it. and it will suck you through the waves like a pin to a magnet or like my oncle would say:'It slides through like a hot knife through warm butter.
:0) = jew. I am THA JEW JUNK
