Old     (gabriel63)      Join Date: Sep 2005       06-06-2007, 6:59 PM Reply
well i went out the other day and was trying to talk to people on the boat when it was moving but just seem to be hard beause of the engine noise.what can i do to reduce this.
Old     (rallyart)      Join Date: Nov 2006       06-06-2007, 7:05 PM Reply
http://www.freshairexhaust.com/#moreInfo
That will make a big difference.
You can also silence the intake air more and add sound barrier material in the engine compartment.
If there are any openings from the engine area to the passenger area you will get noise through those, even if they are small.
(Message edited by rallyart on June 06, 2007)
Old     (99_slaunch)      Join Date: Oct 2005       06-06-2007, 7:07 PM Reply
engine noise or exhaust noise?
Old     (kerryn2skiing)      Join Date: Apr 2007       06-06-2007, 8:51 PM Reply
We have the same boat, and we have not had a problem with any noise exhaust or engine. You could use an automotive foil backed insulation on the inside of the engine cover. But I still find your complaint odd, we really don't have any issues with our engines noise.
Old     (jayc)      Join Date: Sep 2002       06-07-2007, 2:20 PM Reply
Engine noise on a direct drive is a lot more than a V drive seeing as you 8" away from the source of the noise.
Get some decent insulation under the cover.
