Old    Kevin (premierwake136)      Join Date: Jun 2005       06-04-2007, 5:23 PM Reply
i have finally decided to get some extra weight for the boat. i am looking at Fly High Pro X Series V-drive Sacs to go in the storage in th back of the boat. i was wondering if i really needed weight in the front. will the wake be washhed out or what. but i do have the taps 2 which can put the nose down.
thanks for the help
Old    Tanner Russell (tanner)      Join Date: Oct 2005       06-04-2007, 5:31 PM Reply
In the Tige's it's more important to weight the front than the rear. Most the 24V's should enjoy a 50/50 weight distribution or even w/ a slight bit more weight up front than in back.
Old    David Bell (dabell)      Join Date: Apr 2007       06-04-2007, 6:11 PM Reply
Here is someone that has a product that might be up your alley. It's at http://www.tigeaz.com/ and you might want to call them and ask them about the Rival System. The entire ballast system comes with everything that you need to install. After you are done calling them, visit www.tigeowners.com/forum which also has a write up about the install of this product. Good luck.
Old    Kevin (premierwake136)      Join Date: Jun 2005       06-05-2007, 12:21 PM Reply
what would the wake be like if i just had weight in the back
Old    Garret Schmidt (garret_s)      Join Date: Apr 2006       06-05-2007, 1:05 PM Reply
really peaky, and it would end about 55' from the boat.
lol
Old    David Bell (dabell)      Join Date: Apr 2007       06-06-2007, 6:46 AM Reply
I would imagine that the meaty wake will thin out a little bit and increase the height of the wake then. Adding more weight to the front of the boat makes the wake longer in length (less white wash).
