Old    Randy (dudeman)      Join Date: Mar 2005       06-04-2007, 7:11 AM Reply
As the cable comes off the back of the motor and is routed to the front of the motor, it passes thru a bracket with an adjustment on the top of the bracket and one on the bottom. Does anyone know if it matters which adjustment you use to take out the slack. PP is searching right now and will not hold. This has happened before and there is no sense towing the boat to the dealer for a simple adjustment. Thanks in advance.
Old    Someone Else (deltahoosier)      Join Date: Jun 2002       06-04-2007, 8:12 AM Reply
Not sure if I am in the ball game with this, but, when that happened to me I had to simply turn the perfect pass module to wind the cable back. It is on the motor. Beyond that I would have to see it again.
Old    Erick (firemedic)      Join Date: Jul 2006       06-04-2007, 8:35 AM Reply
Call PP. They have outstanding tech support.
Old    Randy (dudeman)      Join Date: Mar 2005       06-04-2007, 9:14 AM Reply
Cable on the motor is tight. I'll try to get in touch with tech support at PP.
