Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-30-2007, 8:21 AM Reply
What is the normal temp at idle speed for a PCM 351 5.8 liter?
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       05-30-2007, 8:23 AM Reply
Mine runs about 160
Old    Nacho (denverd1)      Join Date: May 2004       05-30-2007, 8:29 AM Reply
loaded about 160.
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-30-2007, 8:43 AM Reply
WHAT ABOUT RUNNING?
Old    Sinko (sinkoumn)      Join Date: Jan 2007       05-30-2007, 9:13 AM Reply
What temp is yours running at Eric?
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-30-2007, 11:53 AM Reply
When I am running with a full load it is 160+ but when I come off plane it is any where between 170 and 175.
Old    Sam (wake1823)      Join Date: Dec 2005       05-30-2007, 12:05 PM Reply
when was the last time you changed your impeller? A worn impeller will cause the motor to run hotter at idle.
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-30-2007, 12:29 PM Reply
I just changed it and my thermastate
Old    Art (rallyart)      Join Date: Nov 2006       05-30-2007, 1:28 PM Reply
You can get the temperature spiking up a to 175 when you have been running hard and slow back to an idle. The power you were generating is still heat soaking into the engine and at idle it won't flow as much so it does not cool as quickly.
After just a few minutes though, the temperature should go back to the thermostat setting of 160.
