Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 02, 2007
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       05-29-2007, 9:17 PM Reply
I've been workin on my backrolls for a while now....was wondering if compacting a little bit in the air would allow for more spotting time on the way down. Wondering if anybody has any insights into this or any advice. Its greatly appreciated!! THANKS!
Old    murrayair            05-29-2007, 9:24 PM Reply
Compacting yourself in the air will help you rotate faster, as will keeping the handle close to your lead hip, which will give you more time to spot your landings, but beware of over-rotating.
Old    alan plotz (alanp)      Join Date: Apr 2001       05-29-2007, 10:37 PM Reply
search the trick tips section this pops up, oh, about every 3rd thread.
Old    Jeff (fuller313)      Join Date: Oct 2006       05-30-2007, 9:15 AM Reply
Make sure to keep the handle close to your hips and don't start rotating untill you feel the pop. Then make sure to spot your landing.
Old    Lyle Ramsdell (sunsport)      Join Date: Sep 2002       05-30-2007, 10:48 AM Reply
Ben,
The best way to learn a backroll is to practice it out in the flats. This will help you understand the rotation and how to get the pop correctly without hurting yourself. Once you get to the point you are coming around 3/4 of the way consistently then take it to the wake with a short approach. This trick is not about speed.
