Old     (typhoon)      Join Date: Jul 2001       05-28-2007, 8:47 PM Reply
Has anyone ever used a ported sub on a boat? I am going to mount a sub by the driver's feet and thought about porting it. I am just worried about the moisture rusting the tensil leads? Anyone ever do it?
Old     (pittsy)      Join Date: Apr 2004       05-28-2007, 9:07 PM Reply
my friend has a ported sub in his 05 x star..they took out the stock sub and put that mesh material over the hole and the port fires right into the boat...it is really loud and sounds good. he hasn't had any problems with it.
Old     (dicky_diehl)      Join Date: May 2007       05-29-2007, 10:04 AM Reply
i had 1 ported jl 12 under driver's dash in my mobius had no problems just waterproof your box with fiberglass resign or something else and you will be fine.
Old     (tuneman)      Join Date: Mar 2002       05-29-2007, 10:15 AM Reply
Unless you're an absolute purist and like to tinker a lot, sealed subs generally sound better.
JM2C
Old     (iagainsti)      Join Date: Apr 2004       05-29-2007, 10:22 AM Reply
I currently have a ported JL W6 under the drivers dash of my VLX. The slot port fires up and rattles the crap out of everything on the dash. It sounds good but Im currently swapping it for a sealed box, just sounds better IMO with less air vibration from the port.
Old     (typhoon)      Join Date: Jul 2001       05-29-2007, 10:27 AM Reply
what if the port was pointing forward?
Old     (big_b_21v)      Join Date: Oct 2006       05-29-2007, 10:34 AM Reply
I have a ported enclosure with 2 JL W3's. It sounds pretty good. And the port is firing forward.
Old     (jusstty)      Join Date: Dec 2006       05-29-2007, 11:43 AM Reply
Ported seems to work fine in our nautique.
Old     (iagainsti)      Join Date: Apr 2004       05-29-2007, 11:55 AM Reply
TY-Yes the port firing into open air would negate the vibration, on my boat at least. I have always had sealed subs and this was my 1st ported. Like I said it does sound good but I like the sound of sealed better.
Old     (guido)      Join Date: Jul 2002       05-29-2007, 2:16 PM Reply
Porting is louder and generally handles more power when done properly.....
Unfortunately most are not done properly. There is a lot of software and/or calculations to get the port dimensions correct for the box size.
Sealed boxes are a no brainer. You can build a box that's close to the correct volume and get away with it. Generally most go with a sealed box in a boat or car because of that.
I've done both and ended up re-building the ported box because it had too much port noise (my port ended up being too close to the back wall of the box when assembled).
Old    bigdtx            05-29-2007, 3:37 PM Reply
Ported is good if you is a gangsta hoopsta and like to listen to a lotta "whoop der it is".
Old    deltahoosier            05-29-2007, 4:38 PM Reply
When you run the calculations, you will find in general a ported sub also requires a box that is around 2x the size of a sealed enclosure. It is not like you can take a sealed box and add a port on a whim. Also through the parameters for the speaker, you port needs to be tuned for the speaker. The port adds a 3dB boost at the port frequency and is out of phase with the forward speaker wave. That is why you can play the speaker a little harder because the port helps control speaker motion. One drawback that you may not be aware of is that below the port turned frequency, the speaker can unload on you. My guess is at a harmonic or something. That means your speaker will have zero control at a frequency that will want to shoot it out the boat. So, don't make your frequency too high and that is also why you sometimes see a subsonic filter on some of the old amps.
Old     (chris_b)      Join Date: Feb 2007       05-29-2007, 7:38 PM Reply
Ported enclosures work best when built right for open areas. I run one 12" by the driver's feet, port firing forward. Sealed enclosures are much simpler to build, and work better for closed areas, such as cars, trucks, etc. Ported work better in open areas such as boats. Home theater systems usually run ported subs, because they are usually in an open area. Most concerts subs are the same also. In all, both can be made to sound good.
Old     (882001)      Join Date: Nov 2003       05-29-2007, 7:43 PM Reply
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Old     (mikeski)      Join Date: Aug 2003       05-29-2007, 10:40 PM Reply
In my experience I find sealed subs to work better.
Old     (typhoon)      Join Date: Jul 2001       05-30-2007, 7:14 AM Reply
I talked to a technician/speaker designer and he states that the general moisture in the boat will oxidize anfd degrade the tensil leads within 3 years.
