Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 25, 2007
Old    Allen Sasser (bamacpa)      Join Date: Aug 2006       05-23-2007, 6:08 AM Reply
Of all the wonderful threads on refurbing the teak swim deck, I have never seen or read where anyone finishes the underside of the deck. So, do most of you prepare the underside the same as the top side (sand, clean, brighten, oil it) or leave it be?
Old    Ifishok™ (ifishok)      Join Date: Mar 2002       05-23-2007, 6:37 AM Reply
I just applied oil to the bottom of it. No one ever sees it.
Old    Art (rallyart)      Join Date: Nov 2006       05-23-2007, 8:13 AM Reply
I just apply oil to the bottom and top. Nothing fancy, just do it regularly. The sun dries the top more so it needs treatment much more often.
Old    MIKE O (batman)      Join Date: Nov 2001       05-23-2007, 3:52 PM Reply
Just pressure wash the bottom and oil it! For the top I pressure wash, spray with straight bleach, let set a few minutes, scrub with stiff bristle deck brush (oh and watch out for the bleach), pressure wash again and all that crud comes off. Oil it down and looks good as new!
Old    brian (drifter1136)      Join Date: Nov 2003       05-24-2007, 8:18 PM Reply
I sanded and cleaned then finished the bottom of mine.
Old    Jeremy Hawkinson (hawk22)      Join Date: Jul 2006       05-25-2007, 12:51 AM Reply
Mike, how far gone is your teak step when you do this process? That sounds quick and easy! I am just getting ready to do mine, but the info I got was to sand it down in varying stages (coarser to smoother), then wash and oil. I hate sanding. I may just try your method instead. Have you used the same method for any other teak on your boat? My whole boat is accented with a thin strip of teak so I'll need to do the same. Should I remove it then go through this process?
Old    Nickbot (nickbot)      Join Date: Feb 2007       05-25-2007, 4:43 AM Reply
i do the same process top and bottom. sand -> clean -> oil.
