Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 25, 2007
Old    Jason (calabriaman)      Join Date: Apr 2006       05-21-2007, 6:11 PM Reply
Just this past weekend we hit a floating log and instantly the rattle and shake occurred when going over about 10mph. I figured it was the prop but when we took it out of the water the prop looked fine. I think it may be the shaft. Everything looks fine, so I dont know. Anyone have any thoughts? Anyone bend their shaft before?
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       05-21-2007, 6:34 PM Reply
Chances are it is the prop. Shafts can and do bend, but infrequently. Spray some lube into the cutlass bearing and rotate by hand. You can use a long rod to show shaft bend by letting to rod ride the shaft and looking at the end pulse.
Old    JimmyF (fulltilt429)      Join Date: Apr 2007       05-21-2007, 7:00 PM Reply
Sup Jason, Sucks you guys couldnt make it out to Orwood. Have you had it back in the water since changing props? Anyways if you and your boys need a ride we'll be out Sat and Sun. you got my number. - Jimmy
Old    along (awl)      Join Date: Feb 2006       05-21-2007, 9:18 PM Reply
You may have bent the strut. Check the prop, strut, then shaft in this order. least expensive to most expensive.
