Old    Kevin Hoye (wakebrdr38)      Join Date: Sep 2006       05-21-2007, 10:06 AM Reply
ok just recently when i put my boat in neutral, the prop still spins. its enough to make the boat move forward, but if you open the engine housing you can put your foot down there and stop it easily. my friend has a supra with the same issue. anyone heard of this or know what i can do to get it to stop? its kinda annoying.
Old    Hey, You scratched my anchor! (bftskir)      Join Date: Jan 2004       05-21-2007, 11:56 AM Reply
should be able to adjust the linkage
Old    Rod McInnis (rodmcinnis)      Join Date: Sep 2002       05-21-2007, 2:30 PM Reply
No, it isn't a linkage problem. The linkage opens or closes a valve, it doesn't operate the clutch directly.
The first thing you should try is to change the transmission fluid. It is possible that the oil has just gotten so dirty/gunky that it is causing a lot of drag as the clutch plates rotate.
If that doesn't fix the problem then I am afraid it won't be an easy fix. The likely cause of the drag is that one or more of the clutch plates have warped and they are not totally releasing. The news gets worse: the warpage would have been caused by the clutch plates overheating, and they propably overheated because they were slipping, and they were probably slipping because they were not able to withstand the load.
If you were recently doing something unusual (like towing a large boat) that could have resulted in the transmission slipping, and you are not likely to do that thing again, then you might be okay except for the annoyance. Just be sure to kill the engine whenever there is anyone in the water next to the boat.
If you have been doing your usual riding then I would have doubts as to how long that transmission is going to last.
Rod
Old    Kevin Hoye (wakebrdr38)      Join Date: Sep 2006       05-22-2007, 9:01 AM Reply
thanks for the info, tranny fluid needs changed soon so im hoping that is the issue, however this all started happening after we started running 1600 pounds of ballast instead of the normal 1200 or so.
