Old    deltariders...tim (brick)      Join Date: Nov 2003       05-13-2007, 6:46 AM Reply
Check this out:
When I first watched this clip, I thought Kyle was going for a crow mobe 5, but then I realized he was rotating to a 7. Afterwards, I noticed the video was titled Big Worm 7 attempt, so the question is what exactly is a Big Worm? Thanks.
Old    deltariders...tim (brick)      Join Date: Nov 2003       05-14-2007, 7:29 AM Reply
Well, I think I found the answer. TS frontroll with overhead 7 rotation.
Old    jpbray            05-14-2007, 8:22 AM Reply
No this is a bigworm 7. Is question is what's a big worm. A big worm if I'm right is an overhead crowmobe like the whirly is an overhead mobydick. So bigworm 7 is like a whirly 7. I had never seen that mobe 7 before.
Old    Alex Klimowsow (liquid_force24)      Join Date: Apr 2006       05-15-2007, 12:28 AM Reply
and its not called a big worm 7!!!
its called a big Johnson after Brandon Johnson!!!
Old    Justin (jusstty)      Join Date: Dec 2006       05-15-2007, 8:25 AM Reply
Can you do a Big Worm 3 or 5?
Old    deltariders...tim (brick)      Join Date: Nov 2003       05-15-2007, 12:21 PM Reply
Don't want to say where I found this definition, but, "Big Wurm: A toeside Front Roll with frontside 540. Handle is rotated above the head. Invented by Ryan Davis."
Old    BG WCC (bigpapaf1f)      Join Date: May 2005       05-22-2007, 12:31 PM Reply
Justin, a Big Worm is just a 5, A front roll with a over head fs 3(over head crow mobe) is a Diesel.
Any one have any tips on this(Big Worm)? Last night I got it all the way around but the handle is up to high. I am pumped to get back out and try it again. I think I need to pull the rope down and across my body. Thanks BG
Old    Justin (jusstty)      Join Date: Dec 2006       05-22-2007, 1:07 PM Reply
So a Big worm would be a scarecrow with another 360 overhead spin right? Landing the same way as a scarecrow but just one more spin.
Old    BG WCC (bigpapaf1f)      Join Date: May 2005       05-22-2007, 1:59 PM Reply
You got it! It looks sick, It almost looks like a ts whirly.
Old    deltariders...tim (brick)      Join Date: Nov 2003       05-22-2007, 2:48 PM Reply
Brandon, search on wakepics. There is clip of Kyle Alberts doing a switch big worm. Friggin' sick. No advice, but maybe it will help you with the rotation.
Can't wait to see you huck it next time we ride!
Old    Justin (jusstty)      Join Date: Dec 2006       05-22-2007, 6:23 PM Reply
Thanks a lot man, I got my Scarecrow dialed in, so im thinking about trying worm's. We'll see how it goes.
Old    B.C.P...........Mike (wakeeater2003)      Join Date: Mar 2004       05-30-2007, 7:52 PM Reply
Turn the boat to get slack in the line for the worm. THat is how I learned them. Really edge change hard and concentrate on going straight up. I landed it on like my 10th try like six or seven years ago and have been doing them ever since. IF you do screw up you can eat it really hard with all of the momentum that you have going. Everybody loves when I do this trick but I like the feeling of a crowmobe much more. Good luck BCP MIke
Old    Josh Wells (goatroper222000)      Join Date: Dec 2006       05-31-2007, 5:53 PM Reply
WOAH!! that vid made me dizzy...sweet trick tho
Old    Pottsy (pottsy)      Join Date: Jul 2006       05-31-2007, 7:29 PM Reply
wow, impressive, and so close to landing it
