Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 25, 2007
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-07-2007, 9:08 AM Reply
So I was out yesterday and I hit another boat wake pretty hard the motor then kinda missed for a second I figured since it is a carburated engine that it was not that big of deal but for the next 20 min. or so is was acting a little funny almost missing like. Then it just kinda went back to normal and ran fine for the rest of the day. This is the 2nd time this has happened this year. The motor is a PCM 5.8 351.I replaced the spark plugs this year so it's not them. Any ideas on what it may be?
Old    Tim (dukeno1)      Join Date: May 2006       05-07-2007, 9:18 AM Reply
Check your lanyard....mine was doing the same thing because of a faulty lanyard kill switch. Would cut out when hitting wakes and at other times. May not be your problem but it's worth a shot!
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-07-2007, 9:45 AM Reply
There is no laynard on an Excel.
A miss could be caused by a lean condition or a spark issue. Ohm all the spark plug wires or replace them. Check the distributer. Recheck timing. Replace the distributer cap and rotor. Replace the fuel filter(s). Have the carb rebuilt. That should pretty much cure whatever is the problem.
Old    Mike (nauty_tique)      Join Date: Nov 2005       05-07-2007, 10:25 AM Reply
1st time out this season? Are you sure you don't have bad gas(not from the beans) and or water in the fuel?
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-07-2007, 10:42 AM Reply
When you say lean condition you mean? The gas is not the problem I have gone out several times this season and run several tanks through, so that is not it.
Old    Mike (nauty_tique)      Join Date: Nov 2005       05-07-2007, 10:44 AM Reply
Lean being lack of fuel, Kind of what I was hitting on as well. If you've run a couple tanks through that might not be it. How long since you replaced the fuel filter? Does your's have the fuel/water seperator? If so, is there a lot of water in it?
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-07-2007, 11:57 AM Reply
Just replaced the fuel filter and it doesn't have a fuel/water seperator
Old    Eric McNally (eric_ms)      Join Date: Apr 2007       05-07-2007, 11:58 AM Reply
but here is the thing it will run fine and if a hit another boats wake really hard that is when it will act up. It will stay that way for a good 20 min and then be back to running fine.
Old    Nick (nickypoo)      Join Date: Jan 2007       05-08-2007, 10:16 AM Reply
You sure you didn't knock a plug wire off? Maybe the coil wire? Just sounds like a loose wire somewhere to me.
