Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 13, 2007
Old    Derek Jones (bonty88)      Join Date: Jun 2006       05-06-2007, 10:47 AM Reply
I have a direct drive and I have one 600 pound fat sack I am running in the rear locker. I want to add some more ballast, but I am not sure where I should place it for the most benefit. I want the wake to be larger but I feel the current wake is very steep. I would like to mellow that out some. Any advice?
Old    JoJo Snow (josnow1)      Join Date: Apr 2006       05-06-2007, 10:54 AM Reply
Place weight in the bow...that will help mellow it out a little. Also, do a search, there are several post that will give you detailed advice on ballast placement.
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       05-06-2007, 11:37 AM Reply
Weight in the front.
Old    Stephen Higgins (srh00z)      Join Date: Jun 2003       05-06-2007, 12:11 PM Reply
Weight in the back will definitely make a steep wake, balance it out with more weight in the bow as the previous responses show. I believe that more weight in the bow will also make the sweet spot of the weight a little bit longer before it starts to crest over. I learned that here on wakeworld and I have seen the results.
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       05-06-2007, 12:56 PM Reply
Weighting the front is going to help your boat plane off as well, little bit of a gas savings.
If someone has the time post the link to the recent thread about weight placement.
Old    Derek Jones (bonty88)      Join Date: Jun 2006       05-07-2007, 9:11 AM Reply
Thanks for the help. I will look into putting some weight in the front and see if I can find the previous posts about weight.
