Go Back   WakeWorld > Other Water Sports > Waterskiing
Old     (jzd)      Join Date: Jul 2005       10-06-2005, 8:30 AM Reply
I recently restored a 1994 SkiCenturion Barefoot Warrior.One thing I'm not sure about is how loose or tight should the pylon be.We barefoot & Slalom behind this boat,when I say we I mean 3 guys weighing between 180lbs 210lbs.Should the pylon rattle?
Old                10-06-2005, 1:52 PM Reply
Look underneath the floor where the pylon bolts into the hull. Make sure there's no cracking around the base. As long as that looks fine, you should be okay. I know people that don't even bolt their pylons into the brackets. (Really wierd to see someone just lift their pylon straight out of the floor. I'd never do it.) He's a 35off skier and hasn't ever had any problems. Anyway, all pylons flex so don't worry too much about it. Just make sure there's no cracking around the hull.
ps - if no one else responds try posting this on the boats and accessories board.
Old     (jzd)      Join Date: Jul 2005       10-06-2005, 2:37 PM Reply
Thank you very much AJ.There is no cracking at all.Now I have a restored Barefoot boat
Old     (bftskir)      Join Date: Jan 2004       05-05-2007, 11:23 AM Reply
come on jerry lets see some pics
post that barefoot boat!
Old     (bbeach)      Join Date: Jul 2002       05-07-2007, 5:18 AM Reply
There should be 2 u brackets that bolt the pylon to the stringer base... But AJ is correct there will be some felx and movement...
