Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 13, 2007
Old    mike hillard (otiswunguy)      Join Date: Apr 2002       04-27-2007, 3:44 PM Reply
I have never built a stationary slider before. The water is 5' deep. If I drive 4x4's about 2' into the mud and sand bottom, will this be stable enough? Hope this makes sense. Also has anyone ever used steel fence posts for pilings before. They would drive into the bottom a lot easier and there is all sorts of fence hardware that you could use to mount boards on top with. Any thoughts?
Old    WakeViolater (wakeviolater)      Join Date: Sep 2004       04-27-2007, 3:51 PM Reply
you need bracing to support your verticals.
the best is two braces per upright (one towards shore, and the other towards deep water), but you can just alternate one on each vertical.
Old    Ron (ronnyboy27)      Join Date: Nov 2005       04-27-2007, 5:09 PM Reply
The steel sounds like a really good idea to me. the only thing is rust. It won't last very long, I think.
Old    mike hillard (otiswunguy)      Join Date: Apr 2002       04-27-2007, 5:51 PM Reply
I am only looking to get a season out of it and the metal post idea is so it can be romoved and thrown in the bushes to store.
Old    George Aslinger (mobv)      Join Date: Jun 2002       04-27-2007, 7:33 PM Reply
Local group built a flat bar by driving steel post into the lake bottom, it works fine, I'm not sure it would work for an A-frame.
Old    Ryan Duckworth (ryand121)      Join Date: Feb 2007       04-27-2007, 8:02 PM Reply
If you use steel fence post, why don't you just use the galvanized stuff. It would be perfect for in-water use.
