Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 13, 2007
Old    Brian McHugh (bcmach)      Join Date: Apr 2007       04-24-2007, 2:36 PM Reply
I live in CO and we are about to start our season, The water temp on our lake is about 48-50 at the surface. Will I be ok in a full 4/3 wetsuit? My sessions won't be longer than about 20 min. and I probably won't ride unless it's about 60 outside. I haven't started my season this early before so I just want to make sure we are gong to be safe. Thanks.
Old    shaun (spjc)      Join Date: Feb 2007       04-24-2007, 2:51 PM Reply
have you thought about getting a dry suit?
Old    Brian McHugh (bcmach)      Join Date: Apr 2007       04-24-2007, 3:10 PM Reply
thought about it, would like to avoid if possible, but if thats what I absolutely need then I would.
Old    C. R. (crushing76)      Join Date: Feb 2007       04-24-2007, 4:11 PM Reply
safe? sure.. you might be a little cold, but go for it... everyone has a different tolerance for cold, so where one person might not be able to take it, the next might love it. people are jumping in the water here with nothing but board shorts (62-4 water temp).. and i'm pretty sure my balls would break the sound barrier jumping up into my throat if i jumped in with no suit.
so put your suit on, get out there and jump in.. the worst that will happen is you will be cold. bring some dry warm clothes to change into.
Old    dtw. (notsobueno)      Join Date: Dec 2004       04-24-2007, 8:23 PM Reply
You should be fine. A 4/3 should be perfect for that temp of water IMO. Get a Rip Curl.
Old    Adam (wakeshredder16)      Join Date: Jul 2006       04-24-2007, 8:27 PM Reply
Yea i rode in the delta with water temp around 62 no suit just board shorts and my friend was in a shorty and freezing so its manly the person but you could try it with the full 4/3 and if its to cold for you wait or get a dry suit
