Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old    Manny (mrm2083)      Join Date: Nov 2005       04-06-2007, 7:24 PM Reply
How long do the cast iron manifolds last in saltwater. My boat has closed cooling but the manifolds are raw water cooled. The manifolds have some rust stains driping down from the risers and alot of rust where the manifolds bolt to the engine. I flush them after every use with water and saltaway for 10 minutes and I have 200 hrs/ 1 year on the boat. Is it time for new ones already?
Old    Manny (mrm2083)      Join Date: Nov 2005       04-07-2007, 8:56 AM Reply
anyone know?
Old    882001 (882001)      Join Date: Nov 2003       04-07-2007, 9:00 AM Reply
200 hrs you should be fine. if you are worried about it order new gaskets from skidim break them apart and look at it. i took mine apart decked the two pieces with a beltsander. and reinstalled the new gaskets. good as new. if water is leaking to the outside then you can bet its leaking to the inside of the head, and that aint good at all!
Old    Josh B (joshugan)      Join Date: Apr 2005       04-07-2007, 1:34 PM Reply
I agree with 882001, you should definitely break them apart and sooner rather than later. Pray that the bolts holding them together are stainless steel or another noncorrosive metal. When I tried to get my risers and manifolds apart I broke a number of bolts. (Take note thought that my boat was 17 years old.) (But it's also never seen salt water.) Hopefully you just have to put new gaskets on every few years rather than whole manifold/riser replacements. Best of luck!!!
Old    deepcove (deepcove)      Join Date: Mar 2004       04-07-2007, 4:00 PM Reply
You should get about 7 years out of them. also it is good practice to change the gaskets annually and drag a flat file across them when changing the gaskets. This will keep the surfaces flat and clean in the event you have some salt water seapage under the gasket.
Old    Jay (jayc)      Join Date: Sep 2002       04-08-2007, 12:02 AM Reply
I agree you should get a good 7-8 years from the manifolds.
I run about 80rs a year in salt and with flushing I get about 8 years.
Old    Manny (mrm2083)      Join Date: Nov 2005       04-08-2007, 7:28 AM Reply
So what do you guys recomend? DO I take the risers off, file it down a little, and put in new gaskets? How bout where the manifolds attach to the block, do I replace thse gaskets too?
Old    deepcove (deepcove)      Join Date: Mar 2004       04-08-2007, 8:11 AM Reply
Yes thats what I do. As far as the rusting near the block that is kinda strange. Are you sure it is not from the leak where your riser bolts onto your manifolds? Like the leak could be running down the manifold adn running along where they bolt to the block.
I had a similar thing 2 years ago, I couldn't figure out why my starter kept dying and it turned out I had a leak fron my riser / manifold that was running down the side facing the engine and right into my starter.
