How much air are you guys getting? You CAN do a sort of ollie, and you'll pop a lot bigger. I actually slightly "flatten" out at the wake, let the wake pop the board up (as if you were kicking the tail down), pop the back, then level out with your front foot in the air. I don't necessarily flatten, but you should take a comfortable cut in and try to pop. Grabs and spins will come much easier if you learn to pop.
