04-03-2007, 9:23 PM
I'm looking to upgrade from my deep v i/o chaparral to a more wakeboard specific boat. Problem is, I only have about $25k to spend (kid in college), so that leaves me with used. I'm looking for a v-drive for the space and wake quality and size are important. This type of question probably gets posted a million times, but I could sure use some help on which boats to consider. Thanks for the help.
04-03-2007, 9:29 PM
I woul get a 1995 super sport nautique and pimp it out and put SANTE graphics on it. It has the same hull that the SANTE has. I would also add some weight to it 1000 or so, maybe more depending on prop and engine.
04-03-2007, 9:52 PM
i wish i had 25k and im not in college either. i picked up my supersport for 18500. if i had 25k though id've gotten an x star or a sanger.
04-04-2007, 12:28 AM
you might be able to find around a 2000-01 Malibu VLX for about that.
04-04-2007, 5:45 AM
Another option is an older Maristar. Weighted correctly and with a tower the ride is nice. Plus most of these boats don't have many hours and weren't abused (older non-wakeboarding owners). Check out my profile for mine. I have alot less than 25k in mine.
04-04-2007, 6:35 AM
99-00 MC 205V
04-04-2007, 6:46 AM
here's a Maristar for you. http://www.onlyinboards.com/Details.aspx?ID=898141 Also saw a 2000 CC Super Sport, but it's in CT and would probably cost at least 1k to ship it to you in CA. But it was in your price range.
04-04-2007, 7:15 AM
I've recently noticed the moomba Kamberra. It's a 22 footer made in the early 2000's and it looks pretty nice. Aparently the same hull as the mob v. I,ve seen a bunch priced in the high teens on boattrader, it might be worth looking at.
04-04-2007, 8:07 AM
1998-2000 mastercraft xstar
04-04-2007, 9:40 AM
i'm not sure, is the Kamberra the same hull as the pre 03 mobius? I think they changed the hull for 04 and the 03 mobuis hull is the current outback hull. I might be way off on that though... anyone?
04-04-2007, 10:31 AM
Thanks for the feedback. I've ridden behind a friends Maristar 230v, he added fat sacks to the rear last season. Any suggestions on the best way to weight an older '00 or '01 mc Maristar or should I just concentrate on boats with built in ballast?
04-04-2007, 10:39 AM
I second a used 205V. Im partial to that hull, but that wake is one of the best in the business. Honestly, I would stick with the Supersport or the Prostar hull. The maristar does not get as big and clean as the SS or PS.
04-04-2007, 10:42 AM
I run about 1000lb total in the back and 500 up front, with 80' of rope and 4-5 people at 22 mph and its a very solid, lippy fun sized wake. My 200 VRS which was changed (same hull) to a 210 VRS in 99 is the same hull as what used to be the X-10. I personally couldn't find anything less than 25k that had automatic balast and it's just something I look forward to in my next boat (if the wife will ever allow).
04-04-2007, 10:52 AM
Any thoughts on a Centurian with the "air warrior" package. Seems like a lot of the right stuff and usually priced lower than the boats mentioned.
04-04-2007, 3:13 PM
I just picked up my buddies 1999 Air Nautique for $23 new upholstery, very clean, 600 hours. They are out there just look for what you want and stick to your price. Steve
04-04-2007, 3:38 PM
ive heard great things about the centurion air warrior...section of "watersports retailer"..."with the ski centurion air wairror elite vdrive c-4, you get everything you wan in a v-dive boat. at low speeds, you get a sweet ramp perfect for stomping your latest wakeboard trick, lay into the throttle alittle bit, and watch the wake disappear, leaving a black canvas for your slalom ski. the wraparound seating feels like a floating living room, with a built-in cooler and SonyCD stereo to seal the deal, Standard features include..12 volt dc power outlets, ACME prrp, adjustable wake plate, automatic blige, built-in insulated cooler, center ballast, driver seat with bolster, MERCUISUER 350 MAG w/ MPI (huge)..snap out marine grade carpet, tilt wheel, and a tower..jsut to name a few"... sounds like a hell of a boat at a hell of a price, i say go with the air warrior for the money..entry level starts right around $30,000
04-04-2007, 3:45 PM
You might want to check this out. It's in Sonora which is relatively close to you. Unfortunately it's not the new hull but it is a mastercraft v drive. http://adcache.boattraderonline.com/6/1/9/88165819.htm or this one which is the new style. you could get it shipped and it would probably still be less than the 25K you wanted to spend. http://adcache.boattraderonline.com/6/5/2/88394852.htm (Message edited by ldr on April 04, 2007) (Message edited by ldr on April 04, 2007) (Message edited by ldr on April 04, 2007)
04-04-2007, 3:49 PM
I don't know why the second link isn't posting but just copy it to the adress bar and check it out.
04-04-2007, 7:30 PM
Is $26k a good price for '98 Maristar 225VRS with 170 hours. It has no tower or ballast.
04-04-2007, 7:38 PM
Brad, Take a look at the Sanger V210. It's a very solid boat and the wake is outstanding. You should be able to find a 00-02 in that price range or less.
04-06-2007, 10:21 AM
Brad, whatever you look at, make sure to bring it by & have us check it out. Both on & off the water.
