Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old     (fill_er_up)      Join Date: May 2006       03-25-2007, 2:38 PM Reply
I have a single battery and want to put on a perko type battery switch to turn everything off between uses. I saw something that it could be used on the positive or negative cable side. Any thoughts?
Old     (rallyart)      Join Date: Nov 2006       03-25-2007, 3:36 PM Reply
Put it where you have the least wires. On a car where you have lots of grounded metal around you put it on Positive to make the battery dead even if you short to the chassis so that's the normal but it does not matter.
Old     (bigshow)      Join Date: Feb 2005       03-25-2007, 8:02 PM Reply
Switching the ground side would be very unusual, I'd switch the positive.
Old     (99_slaunch)      Join Date: Oct 2005       03-25-2007, 8:13 PM Reply
I agree with Edward and Art.
Old     (humboldtboarder)      Join Date: Sep 2005       03-25-2007, 9:22 PM Reply
I wire a lot of hot rods from scratch, and I always put the disconnect on the negative side. That way, when it's swithed off, the body & chassis is no longer grounded, making it impossible to ground out to the body or chassis. It really doesn't matter though, as long as there is a break in the circuit. Put it wherever is easiest.
(Message edited by humboldtboarder on March 25, 2007)
