Old    Ryan Duckworth (ryand121)      Join Date: Feb 2007       03-20-2007, 10:23 PM Reply
...I was wondering what would be a good replacement sub. I would want to replace all four of the subs if there is something that sounds better. The horn tweeters sound great, so I need some subs that can keep up. Thanks for any help.
Old    clubmyke (clubmyke)      Join Date: Aug 2004       03-20-2007, 10:49 PM Reply
a midrange driver would be better... you can got some 8 ohm pro audio drivers and run them in parallel for a 4 ohm load...
drivers that fit the bolt circle diameter is the beyma 8g40 or the beyma 8MI100.. if you want to go cheap then the emminence beta....
btw, be sure to check the bolt circle diameter (this is a big deal)
Old    clubmyke (clubmyke)      Join Date: Aug 2004       03-21-2007, 3:52 PM Reply
btw, it will require a slight modifaction of the crossover..
