if these are the skylon deafcon 5 with the dual 8's and 1 hcld then plan on a big amp.. each one is a 2 ohm load so you have a couple different options.. if you want to run in stereo then, a arc xxk 2500 or a zapco 1000/4...i like zapco for the built in line drivers, mixed mono switch, and volume control cable (symbilink)- they make ideal amps for tower speakers whats kinda cool, is you can rewire them for a 4 ohm load and get a couple amps running in briged mono (like jl 300/2's- pretty much any amp will run 4 ohms bridged) or a zapco 1100/1 can do it well..
