Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 09, 2007
Old     (dedicatedwse)      Join Date: Apr 2006       01-11-2007, 8:03 PM Reply
The boat I purchased this fall has dual batteries run through a standard perko switch. I have a few questions regarding charging the batteries during the winter (without disconnecting the battery cables).
Assuming the perko switch is properly wired...
...can I charge each battery individually when the perko switch is turned to "off"?
...can I charge both batteries at the same time with the perko switch turned to "all"?
The logical answer to both questions seems to be "yes", but I want to make sure I'm not missing something. My gut also tells me that even if I can charge them at the same time, it would be better to charge them individually.
Thanks in advance!
Old     (audiopro74)      Join Date: Jun 2005       01-12-2007, 10:10 AM Reply
yes
Old     (sea_ray_dave)      Join Date: Dec 2004       01-12-2007, 10:33 AM Reply
You charge the batteries individually using a battery charger(s) with the Perko in the off position. I am using two Schumacher Ship N Shore chargers. They are smart chargers and they cost 39.95 at Autozone/O'Reillys. They will charge up to 10 amps then monitor the battery so it can be left on the battery as a maintainer. Just check the batteries water levels monthly.
The 1, 2 or All selection just chooses which battery will be the starting battery(s) and also which battery(s) will get the charge when the boat is running.
Don't ever turn the Perko to off while the boat is running- it can blow the alternator.
Old     (loux2)      Join Date: May 2004       01-12-2007, 4:37 PM Reply
I put mine in the "both" position and charge both at the same time. I put the charger on the 1st battery and both get charged at the same time. In three years I have not had a problem. I would also like to know if anyone knows a reason not to charge both at once.
Old     (boss210)      Join Date: Jun 2006       01-13-2007, 1:14 PM Reply
through away the perco switch & go with a battery isolator if you only have tow battries. If you have room add a additional battery for the radio and then use the perco switch for the tow of them, & go with a total seperate battery for the enging. Way better setup than with a perco alone. That way you have got the perco for your radio batterys and the isolator to switch so you dont have to worry about running the radio too long and not being abel to start your boat.
